HVAC blower operates on low only,
Old Aug 6, 2015 | 08:19 PM
Perry Litchfield's Avatar
Perry Litchfield
2nd Gear
Default HVAC blower operates on low only,
regardless of position of blower switch. New Eckler switch, new controls for HVAC. No vacuum leaks, all vent positions operate/change as correct. Ideas?
Old Aug 6, 2015 | 09:18 PM
SSG26K's Avatar
SSG26K
Check connections at resistor block and high blower relay if you have one. Sounds like the new switch is the problem. Remember "NEW" just means your the first one to use it, it doesn't mean it is good. Did you have this problem before you changed the HVAC switch. Also, what year is the car, and I'll assume it has A/C.
Old Aug 6, 2015 | 10:38 PM
riverracer au's Avatar
riverracer au
yes year would help alot....
just thought i'd bump ya back to the top because of your last name, same as mine...
shows we have good taste being 1/2 a world apart
Old Aug 6, 2015 | 11:00 PM
Perry Litchfield
2nd Gear
Ok, it is a 1978, does have A/C. All worked ok until, while driving home with the car, the blower went from high to low speed. As stated, the mode switch works as it should, switching from the A/C vents to heater and defroster vents. Also, when placed in either of the A/C positions, the A/C compressor engages. There is good cold air coming from the proper vents, just no action, other than low speed from the blower.
Old Aug 7, 2015 | 09:44 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The speed is controlled by the resistor and the input wire that is changed by the blower switch. So I'd first go to the resistor and verify that the power is switching wires with the switch. Use the chart below so you'll know which wire to test in what speed. If the power is changing at the resistor then I'd look at the resistor and/or the blower motor.
Post back
Willcox
To HVAC blower operates on low only,
