Does It Ever Stop?
Old Aug 7, 2015 | 08:41 PM
toobroketoretire's Avatar
toobroketoretire
Default Does It Ever Stop?
My '71 has been running flawless for several months and then my luck ran out an 2 hours ago. I took it for a spin then stopped for gas and no start. Crap, what NOW? As I am well known around my area because of my Vette a dude with a 4-wheel drive pickup pulled me home so I didn't have to call a tow truck.
I pulled the starter off and tore the solenoid apart. The solenoid's internal copper ground wire that is spot welded to the solenoid body had broken because the spot weld had made the wire paper thin. I happened to have a newly repaired solenoid on my shelf so I got her going again.
Does it ever stop?
Old Aug 7, 2015 | 09:00 PM
Aggitated Monkey's Avatar
Aggitated Monkey
LOL! Nope....glade it was a quick find and fix
Old Aug 7, 2015 | 09:06 PM
BlackC3vette's Avatar
BlackC3vette
Originally Posted by toobroketoretire
Does it ever stop?
Why are you worried? You have a priceless asset - friends!
Old Aug 7, 2015 | 09:21 PM
toobroketoretire
I am well known around here because of my Vette. As I live in the mountains most everyone has a 4-wheel drive pickup and usually a length of chain or a tow strap. And as I have an eye welded to my front bumper support attaching a chain or tow strap is super easy. Just glad it was a real easy fix and at no expense because I already had a used repaired solenoid in stock.
Old Aug 8, 2015 | 02:24 AM
AdamMeh's Avatar
AdamMeh
Trust me - there are many of us (myself included) that would love to get that much driving time in. 3 1/2 years into owning our '77 and we've only had a few short stints of being able to use it before something else went wrong and it gets parked again until we can fix it.
Old Aug 8, 2015 | 06:08 AM
toobroketoretire
The solenoid was most likely made in China like everything else is. The ground wire had been spot welded so hard the wire was as thin as tissue paper so it broke. Lucky I had a repaired solenoid in stock.
Old Aug 8, 2015 | 08:11 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
Fixing things that break is part of the fun of ownership!...right? ( or so I've been told )...Good Luck!
Old Aug 9, 2015 | 12:04 PM
dgheinen's Avatar
dgheinen
Sounds to me like a situation that could have been a lot worse! You got lucky. Thankfully it wasn't something catastrophic. Quick finds and quick fixes with parts on hand? That's not too bad.
Old Aug 9, 2015 | 12:07 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Does it ever stop?
Nope...
Old Aug 9, 2015 | 12:42 PM
augiedoggy's Avatar
augiedoggy
I bought an old used dodge ram pickup like 8 years ago and for the first 2-3 years it was the same scenerio one thing failed after another... I got real familiar with how the transmission and fuel injection works as well as the sensors... Anyway It did "Stop" for me as the truck has been pretty damn reliable for the last few years...
I have only been able to drive my 74 vette since last august and that was after replacing the engine, exhaust, radiator and rebuilding the brakes so besides issues related to crap in the tank and water in the fuel from a plugged drain hose at the filler area its been good until Wednesday when my ignition module went but at least that was in my own driveway.
Old Aug 10, 2015 | 04:06 PM
Kacyc3's Avatar
Kacyc3
Does it ever stop?
Only if you put it in the garage and never take it out again...but wheres the fun in that.
Old Aug 11, 2015 | 06:24 AM
InfidelCorvette's Avatar
InfidelCorvette
I'm a little over a year with my 77. Only problems I have had involve it deciding it doesn't want various liquids. First the calipers were leaking. Then I rebuilt the power steering pump. Now my fuel line is leaking. I plan on replacing that with a much needed EFI system. Still in a little over a year, it's been the best DD I have ever had
Old Aug 11, 2015 | 06:25 AM
InfidelCorvette
I'm assuming that was my POs philosophy. I'm still sorting out the last of the problems that exist from being driven 4 times a year.
Old Aug 11, 2015 | 10:10 AM
ggroller's Avatar
ggroller
My '68 runs perf...........Nevermind. Don't want to jinx myself.
Old Aug 11, 2015 | 11:15 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Here is how to make it stop:
Rebuild the entire brake system.
Rebuild the trailing arms.
Replace all U-joints
Have the water pump rebuilt or replace it with a quality unit. Also fan clutch.
Ditto the starter
Ditto the alternator.
Take out tach and speedo and have them rebuilt.
have carb professionally rebuilt.
Have dizzy professionally rebuilt.
Replace all cooling hoses,a nd have radiator boiled out.
Have wiper motor rebuilt
Assuming your trans and motor are good, that should take care of about any mechanical issues.
Doing everything at once, keeps things from going bad every couple months, at least for a long time into the future.
Doug
Old Aug 11, 2015 | 11:43 AM
COOLTED's Avatar
COOLTED
Havn't had any bad luck with mine...yet. I've gone about 2000 miles in it this year without too much trouble...as long as I don't shut it off I'm fine.
Old Aug 11, 2015 | 03:27 PM
wisoutlaw's Avatar
wisoutlaw
Default Jinx!
Too late, you just did!
Old Aug 11, 2015 | 03:31 PM
dochorsepower's Avatar
dochorsepower
"The solenoid was most likely made in China like everything else is."
Yeah, starters with cheap rebuilt solenoids are a big problem with these vintage of Corvettes. I learned this many years ago and I've had the best luck with NEW AC-Delco starters built in the USA, if you can find them anymore.
To Does It Ever Stop?
