Header bolts
Old Aug 11, 2015 | 11:03 PM
dontreadonme's Avatar
dontreadonme
Default Header bolts
Reaching out once more to finish last project of the season.
In an attempt to close up all of my little exhaust leaks, I replaced gaskets on the headers. purchased new arp bolts.
Noticed the original bolt on the front right side was missing... When I attempted to install the new bolt, noticed I couldnt get it to bite into the hole leading me to believe the hole got stripped...
Want to try to install a stud into the head in hopes the 'inner' threads are still ok. Have hooker sidepipes and the original bolts were small so i think I might have a chance here...
What size stud and threading am I looking for to try this?
Doesnt sound bad now.. But leaking air around that port because of the missing bolt..
Old Aug 12, 2015 | 02:16 AM
toobroketoretire's Avatar
toobroketoretire
Loosen all of the other bolts THEN screw your new bolt in. But its always best to NOT use gaskets on either exhaust manifolds or headers.
Old Aug 12, 2015 | 04:40 AM
SH-60B's Avatar
SH-60B
The thread is 3/8" X 16. Always use gaskets.
Old Aug 12, 2015 | 06:31 AM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Probably already know to tighten bolts working from center out, remove opposite direction.
I have had good luck with copper gaskets
Good luck
Old Aug 12, 2015 | 11:57 AM
dontreadonme
Thank you much everyone for posting
Hoping theres some thread left!
If not, I know there are a few options out there, all over my skill level... Dont want to think that way.. That stud is giong to work!
Old Aug 12, 2015 | 03:58 PM
REELAV8R's Avatar
REELAV8R
Once you get that bolt in and tighten all the bolts, drive it for a bit let cool and then re-tighten all the bolts, drive some more let cool and re-tighten. The gasket will compress a bit. If you don't go back and re-tighten then you will develop leaks again.
Regular bolts for headers have a way of loosening over time. So either find a way to make sure they stay tight, come back and check them periodically, or get something like the stage 8 header bolts.
I use the stage eight's and have had no issues with leakage or loosening with them.
I find them a little spendy for what they are, but they do work as advertised and the bolts are stainless. Some modification of the locking cam is necessary depending on your primary size.
Old Aug 12, 2015 | 06:22 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by toobroketoretire
.....But its always best to NOT use gaskets on headers.
Old Aug 12, 2015 | 07:29 PM
toobroketoretire
Originally Posted by leadfoot4
Yes, there will be slight leakage when not using gaskets but then there is nothing that can blow out, huh? Chevrolet has never put exhaust manifold gaskets on their engines for that same reason.
Old Aug 13, 2015 | 04:36 AM
SH-60B's Avatar
SH-60B
The OP has headers, not exhaust manifolds, maybe you missed that.
Old Aug 13, 2015 | 05:51 AM
toobroketoretire
Yes, I know he has headers and headers don't require gaskets. Just bolt them up tight.
Old Aug 13, 2015 | 07:16 AM
leadfoot4's Avatar
leadfoot4
Let me reiterate......
Old Aug 13, 2015 | 09:44 AM
Big2Bird's Avatar
Big2Bird
This is funny
Old Aug 13, 2015 | 10:15 AM
Big2Bird's Avatar
Big2Bird
Then why does Chevy make them?
50 year old manifolds that are pitted and warped don't seal so well.
Old Aug 13, 2015 | 10:30 AM
Swiftrider08's Avatar
Swiftrider08
Chevrolet never put exhaust gaskets on their engines huh. Ever work on a C6 Vette. All the LS series use an exhaust manifold gasket. Most say to just reuse the stock gasket when putting headers on a C6. Foolish to not use gaskets on a sbc also. Think your out there on an island all by yourself with this one.
Old Aug 13, 2015 | 05:03 PM
Les's Avatar
Les
OK, I get it now. You like to say silly things and then sit back and chuckle at the responses. Well done!
Old Aug 13, 2015 | 05:45 PM
toobroketoretire
I'm referring to the C3's since this is a C3 forum. In the 20 years I was a professional engine builder and the 30 years since I have never used exhaust manifold gaskets. Just because the overhaul gasket sets include them it doesn't mean you have to use them.
Old Aug 13, 2015 | 05:47 PM
redvetracr's Avatar
redvetracr
where do you come up with this mis-information?
To Header bolts
Old Aug 13, 2015 | 06:48 PM
Swiftrider08
You said Chevrolet NEVER used exhaust manifold gaskets. Makes no difference what forum section this is, you said they never used them period. Wrong. Said you were referring to C3's, well a C3 is not an engine, it's a generation code for a complete car. Not buying the "professional" engine builder comment either. If you really were, you would know better. If you don't want to use gaskets, fine, but the rest of us will. Read any book, attend any class, watch any true pro engine builder, ALL will say to use exhaust manifold / header gaskets. Using your logic there is no need to use head or intake manifold gaskets either. Crazy stuff.
Old Aug 13, 2015 | 06:53 PM
leadfoot4's Avatar
leadfoot4
This isn't the first time, he's put out some mis-information, either. Problem is, people come here looking for solid information, and come upon this kind of misinformation, and think it's accurate. It gives the CF a bad reputation....
Old Aug 13, 2015 | 09:43 PM
Strokemyaxe's Avatar
Strokemyaxe
