Voltage Regulator Ohm Specifications
Old Aug 14, 2015 | 03:24 PM
toobroketoretire's Avatar
toobroketoretire
Default Voltage Regulator Ohm Specifications
Many of you repair your own alternators when they quit charging and for those of you who do here are the voltage regulator resistance values taken from a new voltage regulator. I have found when a voltage regulator quits nothing can be measured.
Be sure to use the 200K scale as indicated.
