Engine Part Identification
It looks like it may have been connected to this hose:
And this plug:
Not sure if this was done by a previous owner or nerfed from the factory.
Thanks!
Pic 1 is the TCS solenoid, would prevent timing advance until the car was warm, part of an entire system
Pic 2 is the vent for the wiper door (supposed to be open)
Pic 3 ...I think should be the plug for the TCS but on mine (72 so it was different?) there was a tan wire and the black and blue wires went into the same spade
M
Last edited by Mooser; Aug 14, 2015 at 05:35 PM. Reason: Un-Changed my mind about #3
Here's a picture of a typical TCS configuration on a 70 sb.
I believe the solenoid in your picture may be mounted backwards.
In pic #3… that wire comes around and plugs into the back end of the TCS solenoid… see my pic.
Regards,
Alan
This pic is from the Dobbins 68-72 Fact Book.
Note hose from distributor advance to side port on solenoid and from front port to nipple on carb.
The TCS system is comprised of a switch on the transmission, a relay on the firewall, a temp sensor in the passenger side head and the solenoid on the intake manifold.
The steelwire braided vacuum line going from the carb to your distributor defeats the intent of the TCS system.
It does appear that mine is mounted in a different orientation than in the Dobbins book.
I wonder if it was 'fiddled' with in the past (as evidenced by the braided line) either because the solenoid broke or for a performance improvement.
I'd think either one of your thoughts might be true.
Many people didn't quite understand the way the TCS system was supposed to work or what it's various parts that Revi listed did… so they disconnected what ever they saw hoping for improved performance.
Regards,
Alan
Just adding that braided line covering to the vacuum advance hose has to be worth probably 50 horsepower.
