New guy with Control issue.
Old Aug 15, 2015 | 01:47 AM
clevan barclay's Avatar
clevan barclay
Default New guy with Control issue.
Hello, ladies and Gents. I have been lurking for a while now and would like to come out and say hello. My name is Clevan .I reside in sunny Cali. I recently purchased a 79 Vette. as my daily driver (rolling resto.)
One problem that have me stomped is..every three months like clock work, The ignition control module goes out. the car will not start until i install a new one. Any idea what is causing this. The car is bone stock wit the exception of the air cleaner snorkel thermo flaps and the exhaust thermo flap removal. I am still trying to figure what engine it has. The car came stock without smog pump and injection tubes, and have a 4 speed.
The vin# is 1Z8789S426530. Thank you all. Clevan
Last edited by clevan barclay; Aug 15, 2015 at 01:55 AM. Reason: to add more info. about the car.
Old Aug 15, 2015 | 07:27 AM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
You will get a better response posting here
https://www.corvetteforum.com/forums/help-forum-31/
Old Aug 15, 2015 | 08:26 AM
guappy's Avatar
guappy
Welcome to the forum
Old Aug 15, 2015 | 08:59 AM
gilhuly's Avatar
gilhuly
welcome to the forum!
Old Aug 15, 2015 | 12:03 PM
toobroketoretire's Avatar
toobroketoretire
Your module may not be "going out" as you suspect. In many cases I have found the 1/4" female blade terminals that connect to the module have opened up (loose) and are no longer making a good contact with the module's male blade terminals. The solution is to simply squeeze the female terminals with needle nose pliers so they plug on firmly.
Old Aug 15, 2015 | 12:08 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Welcome!!!
Old Aug 15, 2015 | 04:54 PM
78anniversary's Avatar
78anniversary
Are you smearing the heat sink compound on the back of the module when you install it? The compound keeps the heat away from the module so it doesn't overheat.
Old Aug 16, 2015 | 02:51 AM
toobroketoretire
The silicon grease is absolutely necessary I'm told but I have always used Permatex Ultra Black RTV because I feel it does a better job. I even have a 1/2" hose running from my evaporator to my distributor cap to keep a flow or cool air blowing across my module (I have 5 vent holes right behind it). I think the biggest problem is the modules are being made in China using inferior parts.
Old Aug 16, 2015 | 05:18 AM
jotto's Avatar
jotto
WTF????? NO!!!!!!!!!!
Dude that is just so wrong. Ive seen ducts being added to aid cooling of brakes, Ive seen cold air induction setups to cool intake air but never have I seen or heard of someone running a pipe to help cool a HEI Module!
The correct compound to put under the module is a paste that conducts heat very well, very similar to what you would use on a CPU cooler in your PC. A silicone RTV compound is just wrong, plain and simple. Im guessing thats why you had the need for the extra cooling pipe.
Clevan welcome to the forum and can you describe how you install the new module.
Old Aug 16, 2015 | 07:23 AM
diehrd's Avatar
diehrd
Are you serious ?
Some advice as bad as all that should be filtered by a moderator plain and simple.
Old Aug 16, 2015 | 07:44 AM
Big2Bird's Avatar
Big2Bird
Where are you getting these modules?
You want to use a Delco or a DUI unit. Use the heat sinking grease included.
Are you in So Cal?
Old Aug 19, 2015 | 05:31 PM
clevan barclay
Thanks for the welcome,and sorry it took so long to get back to you.
I tightened the female terminals as suggested by Toobroketoretire, and i did use the heat sink lube that came with the module. Jotto, the placement of the module was straight forward.The car cranked right up. The problem is, after about Four hundred miles or so it fails again. The last two modules were purchased from O'Rileys ( Master Pro Ignition) If the problem rears its head again i will put a Delco part in. Thank you all for the suggestions, and i will keep you posted. Big2Bird, I am in Perris and its hot out here. Thanks again. Clevan
Old Aug 19, 2015 | 05:39 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Personally I would just buy a new distributor. You can get them for less than $85 now for the whole thing. Plug it in and go. If you are eating modules....something may be shorting out the "#1" circuit....which is the one that controls sparking at idle.
Speedway has a decent one for $70.
http://www.speedwaymotors.com/Speedw...09170000027814
BTW.....the heat sink grease on the module does not insulate the module from heat......it actually enhances the transfer of heat to the distributor housing. Much like a computer motherboard heat sink. The grease is the conductor.
Peace,
Jebby
Old Aug 19, 2015 | 05:44 PM
Big2Bird's Avatar
Big2Bird
Yep. No name modules are chinese trash. Delco or DUI will last at LEAST 10 years or more.
Old Aug 19, 2015 | 05:48 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I just caught this....sorry for the repeater.....
Jebby
Old Aug 19, 2015 | 05:53 PM
Big2Bird's Avatar
Big2Bird
Your cure is to use insulating material between the module and heat sink, then blow air across it?
Did you learn that in Thermodynamics class?
Old Aug 19, 2015 | 06:23 PM
REELAV8R's Avatar
REELAV8R
I've got no words.
Stupid round wheels, so much better if they were octagonal.
To New guy with Control issue.
Old Aug 19, 2015 | 06:29 PM
AboveTheLogic's Avatar
AboveTheLogic
At $25 a module every 3 months, it wouldn't take long to hit the ROI on a MSD module that I'm guessing has better durability than the GM style from who knows where...
Old Aug 19, 2015 | 10:06 PM
lionelhutz's Avatar
lionelhutz
You could try a replacement coil at the same time as the new module. But, it could easily be that cheap module. You'd probably end up with poor quality parts that could fail just as easily buying a cheap new distributor.
The stupidity is everywhere. RTV isn't thermally conductive. You were probably comparing the RTV to dielectric grease which is wrong too.
Old Aug 19, 2015 | 10:31 PM
toobroketoretire
RTV is extremely thermally conductive and that's why I'm using it.
