Cylinder Head recommendations please
Old Aug 15, 2015 | 08:42 PM
COOLTED's Avatar
COOLTED
Default Cylinder Head recommendations please
Soon I will be upgrading my '79 L48. I am going to put an L82 cam in, and want new heads. I want proper flow for the cam and more compression. This car is a cruiser, and I am going to leave the short block alone. I am also gong to stay with the Q-jet.
What have you guys used or suggest?
oh yeah...I don't wanna spend a ton of money. 1/2 ton maybe.
Old Aug 15, 2015 | 08:50 PM
Jartanyon's Avatar
Jartanyon
You get what you pay for with heads. I went the cheap route in the beginning - 3 pairs of heads later, I bit the bullet and bought AFR heads. Could have saved myself a lot of time and troubles by going that route in the first place...worth every penny IMHO.
Old Aug 15, 2015 | 08:58 PM
derekderek's Avatar
derekderek
half ton will get aluminum from jegs. edelbrock to brodix 800 to 1200. or AFR's for 15 or so. stay under 210cc intake runners. staying q-jet but you wanna research how much more intake will fit under the hood. just paint heads and intake orange. and keep the old parts. the next buyer will never reinstall them either, but he considers the car worth more it they are there.
Old Aug 15, 2015 | 09:27 PM
GUSTO14's Avatar
GUSTO14
The Dart Iron Eagles available from many vendors are a bargain and flow better than almost anything the factory ever installed on the small block Chevy. And, they won't break the bank!
As you'll see in the video, these aren't exactly OEM cylinder heads either...
Good luck... GUSTO
Old Aug 16, 2015 | 09:05 AM
jb78L-82's Avatar
jb78L-82
Assuming you have 8-8.5:1 compression you would want a 64CC head for a 1 point bump in compression so you would end up at something between 9-9.5:1 which is perfect. I went for the gusto on my rebuild of my L-82 with AFR Aluminum 180 64 CC heads and a roller cam but if you stick with a flat tappet cam I would think maybe a comp cam XE268 might be better with .477/.480, LSA 114, Duration 224/230, Operating range 1,800-5,800 RPM, depending what you want...Stick/Auto. The L-82 cam is .450/.460, duration 222, LSA 114. With an aluminum head versus Cast iron you could probably run 87 octane with no issues. I run 89 with my 10.2:1 compression with zero detonation....aluminum heads have great detonation resistance versus iron.
Old Aug 16, 2015 | 10:11 AM
Kacyc3's Avatar
Kacyc3
Is there a reason you want to use an L82 Cam?
Old Aug 16, 2015 | 11:49 AM
augiedoggy's Avatar
augiedoggy
Dart Iron Eagle - OEM Cylinder Head Face Off - YouTube
Good luck... GUSTO
These are the exact heads I use...only I bought mine for $300. on craigslist and they came with harland sharp 1.6 roller rockers... The flow numbers are not the greatest on the intake side compared to other aftermarket heads but they work well and can create some serious power.. BTW they work better with the characteristics of the lunati voodoo 262 cam than the comp 262 cam... at least in the dyno2000 software Iused.
Old Aug 16, 2015 | 12:07 PM
augiedoggy's Avatar
augiedoggy
Heres the dyno 2000 printout for my setup... The newer cam technology is vastly improved over the older l82 cam so its more efficient... closer to the performance of a roller cam. the flow numbers for the iron eagle heads are in here too.
I tried many different similiarly sized cams in the simulations and this cam had the best performance and power curve for our gearing.
The one difference you have though is dished pistons (i have flat tops) So you may want a cam that bleeds off less dynamic compression for your setup....
File Type: pdf
Old Aug 16, 2015 | 12:16 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Very often overlooked here are the Sportsman II heads.
They are great heads and flow very well for the price. I got 300RWHP and 340RWT with them on my warmed over L48
Old Aug 16, 2015 | 12:27 PM
augiedoggy's Avatar
augiedoggy
They were designed by dart where they not? I though I remember someone telling me the older dart and sportman heads were the same and the companies later split and are unaffiliated now.
Old Aug 16, 2015 | 08:00 PM
ykf7b0's Avatar
ykf7b0
I'm upgrading my 76 L48 with a factory 062 vortec head swap and adding a set of Hooker long tube headers. Not doing a cam swap at this time. Low buck for now.
Old Aug 16, 2015 | 10:48 PM
rcread's Avatar
rcread
I would (and did) go with AFR 195 heads. Chevy heads are so cheap that the difference between a budget and top of the line head is negligible.
Old Aug 16, 2015 | 11:15 PM
COOLTED's Avatar
COOLTED
This is great! Thanks for all the advise. It's been a long time since I have put together a 350, and I didn't have the internet back then for help. With all your help, I'm sure I will be able to get a good cam/head match.
Kacy, I chose the L82 cam for a couple reasons. Keep vacuum for the headlights, easy driveability, and I wanted to keep a Corvette cam in it, I want it to sound like a Corvette, not like every other SBC out there. Vettes seem to have a distinct sound, and I think the cam is a part of that. Feel free to tell me if I'm wrong on that last point.
Thanks again guys.
Edit...I, I...I dunno. getting late.
Old Aug 17, 2015 | 06:19 AM
jb78L-82's Avatar
jb78L-82
Thanks again guys.
FWIW...I did not notice any sound difference with my L-82 with OEM 882 heads, 2.5 inch duals with Monza Turbo Mufflers and Shorty Headers, L-82 cam, TRW OEM L-82 9:1 Pistons versus the rebuilt L-82 with AFR 180 heads, JE Forged Racing 9:1 pistons, and Howards Roller cam (.525/.525, duration 219/225, LSA 110) with the same exhaust. The decibel level of the exhaust increased after the rebuild (lots more HP and 10.2:1 compression) but the overall exhaust tone remained the same...The Howards Roller I chose has very good vacuum and had no effect on the operation of the headlights, power brakes, etc.....I inverstigated that cam for vacuum with our cars before I bought it and was given the green light by Howards and some on the forum.
Old Aug 17, 2015 | 07:44 AM
augiedoggy's Avatar
augiedoggy
Any of the cams suggested including either of the 262 cams will have great vacuum for the lights and brakes... mine work fine. and as for sound... if I parked a bunch of cars in a row and ran each one for you to listen to, you would have no idea which had the l82 cam. I would not go with that cam. It would be a step backwards from your goals.
Old Aug 17, 2015 | 07:51 AM
TedH's Avatar
TedH
A good Comp Xtreme Energy cam that fits your application (flat tappet or roller), will better match your new heads than the L82 cam.
Old Aug 17, 2015 | 12:33 PM
ykf7b0's Avatar
ykf7b0
I paid $150.00 for two sets of vortec heads. One set were 062's and the other were 906's. I sold the 906's on ebay for $280.00. How much were those AFR's? I bought the new Hooker Competition ceramic coated headers that were sold as blemished ( I still haven't found the blemish) for $225.00 shipped. I paid $100.00 for a vortec intake. So far, I am $195.00 in the red. I know most will not find these heads this cheap but they are out there and are a great performance upgrade if you are budget minded. You can tie up more money negating some of the savings if you go high lift. It's always basic math - It cost more to go faster.
To Cylinder Head recommendations please
Old Aug 17, 2015 | 02:40 PM
bluedawg's Avatar
bluedawg
Sametime here with the exception that i bought one set prior to buying the afr. The thing is that a decent set of heads needs a camshaft to compliment the combo.
Old Aug 17, 2015 | 03:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
An AFR 180 head, Isky 270 mega cam good dual plane, 1-5/8 headers would be a strong reliable street combo. Yes its an old school cam but it works well and should operate your vacuum stuff fine, can def tell it has a cam in it but wont shake the fenders off, can DD it no problem;imo it will run stronger and sound better than the L82
Never had an Isky go flat to boot.
If it were me Id have that logo ground off the front of the heads, rough it up then paint. Never cared for large by huge logos. Youre getting good advice on heads, spend it once buy the best one you can. Wish Id listened to that yrs ago (did the ported world/dart head thing money down the drain)....one day Ill have some AFRs on mine.
Million ways to skin a cat opinions will vary
Old Aug 18, 2015 | 12:38 AM
rcread's Avatar
rcread
I think they were only about $1400. That's what I love about Chevy small block stuff - it's dirt cheap.
