Proper Fuse Amps?
Old Aug 16, 2015 | 03:04 PM
Aggitated Monkey's Avatar
Aggitated Monkey
Default Proper Fuse Amps?
I have wired in a relay from a keyed/ignition 12 volt. The relay provides 12 volts through a 60 AMP CB directly off the Batt to a 4 gang fuse box. From that box I'm running:
1. A 10 gage wire back to the tank for the electric fuel pump.
2. A 12 gage wire to the TCI 700r4 lock up.
3. A 12 gage wire to the electric choke.
What AMP Fuse would be needed for the 3 positions. I have nothing in the form of instructions that gives me the needed fuse.
Old Aug 16, 2015 | 03:13 PM
Big2Bird's Avatar
Big2Bird
Depends on the loads. 150% x load is safe.
I would think 10a fuse each is fine for those. Probably about 4-5 amps each.(Load)
Old Aug 16, 2015 | 11:35 PM
REELAV8R's Avatar
REELAV8R
A fuse is typically to protect the wire in a circuit not the item being powered.
A 10 gauge wire can handle approx 30 amps.
A 12 gauge wire can take approx 20 amps.
Generally speaking that is, length of run and temperatures encountered can alter those values.
If you want to protect the item being run then you can reduce the value of the fuse below that of the maximum for the wire.
You cannot/should not run an item that will pull continuously more amperage than the wire is rated for.
Check out this chart:
http://assets.bluesea.com/files/reso...on_chartlg.jpg
Old Aug 17, 2015 | 12:24 AM
mikem350's Avatar
mikem350
For my designs, I like at least 200% x load. So would be 15 amp fuses with the size wire you are using.
Old Aug 17, 2015 | 12:41 AM
bluegtp's Avatar
bluegtp
Size wire to handle the circuit load (FLA, full load amps) and size the fuse to protect the wire.
Old Aug 17, 2015 | 10:39 AM
Aggitated Monkey
Thanks for this information. I though those rates would be what I need just wasn't totaly sure. I just dont want an ele fire because a component like the pump fails or is failing. Now that I know what value to use on the fuse I should have a sound system.
To Proper Fuse Amps?
