what am i doing wrong?
Old Aug 17, 2015 | 01:23 PM
upnorth's Avatar
upnorth
Default what am i doing wrong?
I installed my new carb have everything running pretty good trying to fine tune it . at idle 700 rpm im running 8 inch lbs of vacuum , 10 at 1000 and just over 15 at 1500 rpm ( there's very little bonce in the gauge at the different rpms ) . the carb came with the 4 idle mixture screws at 1 1/2 turn out .when trying to get the most vacuum I have to turn the screws to almost bottomed out ( can't be another 1/16 turn left )before anything changes the rpm goes up a little and so does the vacuum . runs ruff going the other way .
Old Aug 17, 2015 | 01:50 PM
JimLentz's Avatar
JimLentz
Have you checked for a vacuum leak?
Old Aug 17, 2015 | 02:21 PM
MelWff's Avatar
MelWff
did you check the float levels first?
Old Aug 17, 2015 | 02:34 PM
centralcalvette's Avatar
centralcalvette
1) What was the vacuum before changing carbs ?
It either has a vacuum leak(most likely, base of carb) or the timing is off. Did you change the timing at all? You should have 19 inches of vacuum at idle.
Old Aug 17, 2015 | 02:47 PM
REELAV8R's Avatar
REELAV8R
I'm going to guess this is a large cam engine with little vacuum available? If not disregard.
If you have already made the base adjustments and still find that you need to have the throttle plates open pretty far to idle I would say you have insufficient idle bypass air.
Big cams with little vacuum need a way to get fuel and air without having to open the throttle blades. Bypass air is the ticket. The stock bypass circuit which is part of the idle circuit may be too small. One crude way it used (and sometimes still is) to be done is by drilling holes in the throttle plates.
Read this article it may help. Then see if you can locate the bypass circuit on your carb.
http://www.hotrod.com/how-to/engine/...rberutor-tune/
Old Aug 17, 2015 | 03:45 PM
tracdogg2's Avatar
tracdogg2
Where did he say he's running a double pumper?
Old Aug 17, 2015 | 04:09 PM
upnorth's Avatar
upnorth
pretty sure I don't have any vacuum leaks , it had low readings with the other carbs I have had on it .haven't ran a double pumper since the 80s . its a quick fuel hr-680-vs . talked to two different guys there first one said its running to rich and go from 70 to 73 on the idle air bleeders the other said to go to 76 im going with the 76 . the one thing I cant remember is what size cam I have . pretty much know the rest . speedpro 11 to 1 pistons 30 over , engines decked 40 , world sport 2 heads 64cc 202 160 with angle plugs , roller rockers . had the whole thing balanced . I use to work in the auto industry so I could get parts at cost . also use to go over to where they built the Kodak car In Virgina. so im had a little inside info but that was many years ago . one thing i can't remember is what size cam . was going go get a chassis dyno run ,but after watching the dyno failures on youtube don't think its ready for that to many old parts in back end .
Old Aug 17, 2015 | 05:09 PM
LT-1 kid's Avatar
LT-1 kid
what tobroke said about Dbl pumpers is true sort of, but my 427 runs very good with a Dbl pumper.
Old Aug 17, 2015 | 05:19 PM
tracdogg2's Avatar
tracdogg2
Prior to going to FI Ford used Holley 4 bbl carbs on trucks and vans. They had 4 corner mixture screws. Toobroke is wrong..... again.
And my double pumper works just fine on my 355. With no lag between gears, which is the whole reason behind double pumpers.
Old Aug 17, 2015 | 10:19 PM
cooper9811's Avatar
cooper9811
TOOBROKE - He said, and I quote "its a quick fuel hr-680-vs " - that says vacuum secondary to me, not a double pumper. We all understand you don't subscribe to their use - fair enough, but let's ease off - no need to talk down to someone asking for help.
Upnorth - how are the transition slots set up? I would start with that and float levels as suggested. Outside of that, I would not hesitate to seek advice. The top of my list are people like Lars and Cliff Ruggles, but there are many other knowledgeable folks to draw on here - if you are patient you can pull out the good advice.
Knowing your engine specs might help us.
Old Aug 17, 2015 | 10:38 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by toobroketoretire
I am always amazed how weekend warriors think they're smarter than the professional college degreed factory engineers who design these cars.
There's the pot calling the kettle black.
Old Aug 17, 2015 | 10:47 PM
augiedoggy's Avatar
augiedoggy
I agree here... the 680 carb should be jetted lean from the factory for a 350ci engine... my 670 was very lean but it idled rich for the PO because he had the primary throttle blades too far open and it was idling off the primary circuit instead of the idle circuit. ... if it doesn't stall when you turn the idle screws in thats your issue for sure, too much transition slot showing underneath.
Old Aug 17, 2015 | 10:51 PM
Big2Bird's Avatar
Big2Bird
So it's just not me?
Whassup Mike?
Old Aug 17, 2015 | 11:15 PM
toobroketoretire's Avatar
toobroketoretire
Okay, I missed the part about the "VS" (vacuum secondary) because it wasn't mentioned in the original post so I admit I made a mistake and I apologize for that error. We all make mistakes from time to time and I made one there.
But that still doesn't change the "need" for 4-corner idle mixture screws for a small engine like a 350" that draws very little air at idle. I suggest closing off the secondary butterflies to almost stuck and bottom the mixture screws so all of the idle air is passing thru the primaries.
And street engines perform better throughout the entire rpm and load range of street driving with vacuum or AVS carburetors which is why the factories always used them.
Old Aug 17, 2015 | 11:23 PM
Big2Bird's Avatar
Big2Bird
Lots of assuming here.
Factories have warrantys, and they limited performance in many places.
Even new Vettes have the computers detuned.
Old Vettes had the 1 turn preload on the liftersto limit the top end and reduce warranty work..Trust me on this one.
I HIGHLY suggest you read Lars papers on carburetors. It "just" may change your way of thinking on just how they really work.
Even on a vacuum secondary like a Holly, you HAVE to set the transition slot square, and set the primary and secondary throttle plates equally open for it to function correctly. Not BS theory, just the facts.
Old Aug 18, 2015 | 09:43 AM
upnorth's Avatar
upnorth
little more info . when I first installed the carb and started it . it ran real rough and missed as it warmed up was real rich smoked up the garage . but after it warmed up it sounded and ran fine . all I did was adjust the idle speed ,the fuel bowl windows show its just a little over 1/2 the window on both . put a regulator and fuel pressure gauge on it . said it was adjusted at the factory for 6 1/2 lbs its right at it according to the gauge . when I took it out it ran better right out of the box then my holley , had it up to around 70 real good response from right off the line and anywhere in between .the big problem is when starting cold, adjustusting the four screws ( turning out it went lower )turning in they made very little difference until bottomed out and that was maybe 1/2 lb of vacuum and not enough gain in rpm to notice . I should get the new idle bleeders in the next couple days .
Old Aug 18, 2015 | 10:16 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Cam and lifters
How many miles on the cam? Low vacuum can be from all of the above but it also can be caused by a problem with the valve train. Are the valves properly adjusted? Is it possible that the lifters are bad or the cam is wiped? My big block Chevelle had a similar problem that drove me crazy. I replaced the cam and lifters and all is good. The cam and lifter set I took out had zero miles on them. The engine did sit for 7 plus years before I got it. Good luck. Jerry
Old Aug 18, 2015 | 11:30 AM
upnorth's Avatar
upnorth
maybe 10,000 . when built I had problems I would blow out the front intake gaskets and from new rebuilt the car always used oil . now this year I have run it more and harder and hardly ever have to add oil and little if no smoke out the back .
To what am i doing wrong?
