Choke rod
Old Aug 22, 2015 | 11:44 AM
V4motorsports's Avatar
V4motorsports
Default Choke rod
My choke rod keeps falling off, what can I do about it?
Russ
Old Aug 22, 2015 | 11:53 AM
toobroketoretire's Avatar
toobroketoretire
Judging from the tweaked-open slot in the lever it appears someone pried the slot open to get the link off at one time and left it tweaked-open. Put the link back on and carefully squeeze the slot "more closed" and the link will stay put. And that link isn't a "choke" rod but rather the rod that (with the diaphragm) prevents the secondary air valve from opening too fast (same reason why mechanical secondary carburetors were never intended for street use).
Old Aug 22, 2015 | 05:07 PM
V4motorsports
Thanks for the reply, took my needle nosed vice grips and squeezed the link closer together. Just tight enough to hold the bent end but not tight enough to prevent it from moving.
Took it out for a drive and it seems to be staying put.
Thanks again
Russ
Old Aug 23, 2015 | 09:45 AM
toobroketoretire
Thanks again
Russ
It also looks like the bent end of the rod got straightened. That bent end should be at a 90 degree angle to the slot so it remains in the slot. The diaphragm is there to prevent the secondary air valve from opening too quick and bogging the engine so its necessary to have it operating correctly. That diaphragm SHOULD hold vacuum so check it before assuming its okay.
Old Aug 24, 2015 | 01:51 PM
Dave J's Avatar
Dave J
Russ, Spin the choke rod around 180 degrees, it should stay in much better!
Old Aug 24, 2015 | 01:56 PM
71 Green 454's Avatar
71 Green 454
That's it....I thought it looked different than mine.
Old Aug 24, 2015 | 07:19 PM
V4motorsports
At first I couldn't figure out your picture, then the light bulb went off!
Wonder why someone would have turned it around?
I haven't played with the carb since I bought the car.
Thanks again
Russ
Old Aug 24, 2015 | 07:58 PM
Big2Bird's Avatar
Big2Bird
They replaced it or rebuilt the carb, but forgot which way was correct.(Bubba)
Old Aug 24, 2015 | 08:03 PM
Dave J's Avatar
Dave J
Bubba definitely gave you a visit
To Choke rod
