rear spring
Old Aug 24, 2015 | 07:37 PM
riverracer au's Avatar
riverracer au
Default rear spring
'72 - 350 - auto
my rear spring has gone level, slightly over centre with 1/2 tank fuel.
as the $$ is crap at the moment to import downunder, i'll look at getting it re done local.
but they need to know what it should be to start with.
from my findings the stock spring should be 9 leafs @ 196lbs,
but they need to know the arch height / tip length before they can do anything.
does anyone have this info?
Old Aug 24, 2015 | 08:25 PM
DonnieP73's Avatar
DonnieP73
I have a photo of my original spring before I restored it, but don't
have any dimensions for it. I found this online maybe it will help you.
http://www.sdtrucksprings.com/index....oducts_id=9582
Will post my photo if you think it might help.
Donnie
Old Aug 24, 2015 | 08:39 PM
riverracer au
thanks, that chart is a start.
FYI:
there is spares place in another capital city down here, he has the spring in stock,
but his price is 580$ for a stock 9 leaf, +50$ shipping to me....
hell of a mark up on a spring you can buy for under 200$ over there..
Old Aug 24, 2015 | 10:51 PM
riverracer au
are the rear springs the same between a sb and bb?
i know my 350 has a 9 leaf std, what did the big blocks use?
Old Aug 24, 2015 | 11:53 PM
DonnieP73's Avatar
DonnieP73
I believe the stock 9 leaf was used on all unless
you had optional F-41 suppension that had 7 leaf.
Someone will correct me if I am wrong.
Donnie
Old Aug 25, 2015 | 12:17 AM
derekderek's Avatar
derekderek
the only weight diff in the rear between bb and sb is bb is a little lighter cuz there is never very much gas in the tank...
Old Sep 8, 2015 | 09:09 AM
riverracer au
Default Update Time
here's a photo of my original rear spring not looking too good, bent upwards.
got hold of a second hand spring local. (read my other post on the rip off price here for a new one)
my original 72 at the top, replacement at the bottom, think it was from a 76, both 9 leaf rated @ 196lbs.
holding in position whilst getting the diff bolts correct length, as the new spring is thicker the the middle by about 5/16".
you can see how low i was by the scraping in spare tyre carrier.
snugged bolts up firm, but not over tight yet.
put the wheels back on, lowered to the ground, torqued up the diff bolts under load,
drove back/forth over the driveway gutter and up n down the street to help settle it,
replacement spring bends upwards like the original one.. they are the original 6-3/8" long trailing arm bolts.
measured under the side rail, body is sitting even/level at approx 5-1/4" front n rear. running 235/60r15 @ 32psi.
so what's going on?
have i gotten another worn out / soft spring, or is something else going on?
Old Sep 8, 2015 | 05:04 PM
riverracer au
Thinking over night, could the spring liners have anything to with how it's behaving?
Old Sep 8, 2015 | 09:10 PM
riverracer au
had a look at a couple of mates cars at the weekend, their springs definatly bow downwards...
stock spring, stock length bolts, new rubbers etc,
and i was worried that it would be too high like a 4wd....
karnt run a glass spring due to our historic rego rules where i am.
thinking, thinking, maybe a few of these will help....
Old Sep 9, 2015 | 08:08 AM
Alan 71's Avatar
Alan 71
Hi rau,
I believe the original 9 leave springs through 1977 had the 3 straight upper leaves.
I see the replacement spring doesn't have them; that makes me wonder why, and could it be part of the cause of what you're seeing (is this a stock spring)?
Regards,
Alan
Old Sep 9, 2015 | 09:01 AM
riverracer au
found this whilst looking for answers
http://www.eatonsprings.com/corvettespringends.html
as far as i could tell my vette is mostly original, unmolested,
most vendors i've looked at for a new spring are all curved leafs.
the replacement i got was from a '76, but not sure if it was original to that car.
thinking outside the box here,
what if i was to pull the old spring apart and add the longest leaf to the replacement spring to make it a bit stiffer?
either remove the smallest leaf to keep the same mounting thickness or leave it on and use 10 leafs and get 4 more longer diff bolts ?
rough (bubba-ish) i know, but getting a spring sent down here would take weeks, and the exchange rate is crap at the moment also...
Old Sep 9, 2015 | 03:34 PM
Haggisbash's Avatar
Haggisbash
So, was there a particular reason why did you not get the original spring re-tempered using the dimensions you were given?
The spring in my 70 looks like your one when it is off the vehicle but not like yours when fitted. Th PO had it re tempered in an effort to fix a sag on the LH side of the car, this was a mistake, I found out that it was clapped out front springs that caused the problem. Regardless though the re-tempered rear spring seems fine.
Old Sep 9, 2015 | 05:05 PM
riverracer au
There is only one place in the state I live in, went there and they karnt get the same size steel,
Even then, as it's so old, they won't warranty it as it will probably sag again in 6mths.
As you probably know Haggish, our dollar has crashed against the US dollar atm.
So importing a new spring is out for now.
And the shop in Sydney wants 580$ + for the same spring you can buy over there for around 150$.....
Old Sep 9, 2015 | 05:34 PM
Alan 71's Avatar
Alan 71
Hi rau,
I read the info at the Eaton link.
It's interesting, and as you posted the all arched spring is possible although it may have been the service replacement.
I don't think there's any reason not to add the leaf as you describe, but I would do the test drive carefully to see if/how it may have changed the ride characteristics.
Certainly because of the cash you're talking about a little experimentation is in order!
Regards,
Alan
Old Sep 9, 2015 | 06:11 PM
riverracer au
Thanks Alan, with your words of encouragement, I'll give it a try.
Will remove the shortest leaf, and add the longest from the old to the replacement.
Will place on top of existing long leaf.
Don't think the central assembly bolt will be long enough for 10 leafs.
Old Sep 10, 2015 | 10:08 AM
riverracer au
well now i'm really confused, the replacement spring i got hold of is 10 leaf.....
pulled it apart to clean and replace the liners, and ended up with 10 pieces of steel....
so do i add the extra big leaf to the original and make it a 10 leaf, or add it to the replacement and have 11?
or pay the ridiculous price being asked local for a new spring ?
Old Sep 10, 2015 | 10:22 AM
rdroket's Avatar
rdroket
You can do a lot of experimenting for $580.00.....jmo
To rear spring
Old Sep 10, 2015 | 04:13 PM
Haggisbash's Avatar
Haggisbash
Sounds like they are only offering re cold re-arching? General consensus seems to be that this is only a temporary fix because the steel has a memory and reverts to its previous shape in a year or so. If all of the leaves are in good condition they need heat treating to remove the memory before being re-arched and then tempered.
I agree with the above comment you can do a lot of experimenting for $500 :-)
FWIW Our $$ has dropped relative to the US as well curtailing my spending somewhat! I'm glad I got my transmission sorted before the b*m dropped out of our dollar.
Old Sep 10, 2015 | 05:42 PM
riverracer au
the place i went to is a industrial spring manufacturer, they do every thing from small to lrg, round n flat, they have furnaces.
The main thing is why does it have 10 to start with.......?
i've gotten some longer diff bolts again, going to paint the leafs, new liners between,
then i'll try a couple of combinations till it arches the correct way.
getting pretty quick at removal and instillation of the spring...
haven't put the pipes back on yet as they sit right under the diff bolts..
Old Sep 11, 2015 | 08:27 AM
riverracer au
assembled the spring with all new liners using the lrg leaf off the original on the bottom, making 11 leafs.
sat too high looking like a 4wd, so i removed the 2 shortest leafs, one at a time, reassemble, installed, repeat...
spring faces the correct way, will take for a spin morow and see if it settles much, and how it rides.
feels firm when bouncing it up n down, not soft n spongy like before.
