steering skips
Old Aug 24, 2015 | 08:01 PM
vetpace78's Avatar
vetpace78
Default steering skips
I've just replaced control arm bushings, put vbp 550 springs in and blistein sport shocks in. Did the alignment myself. Also put a new ps control valve in a year ago but haven't drivin it until now.
The problem is at slow speeds or stopped when I turn the wheel the tires seem to skip or jerk. Could this just be air in the lines or the alignment or the gear box? BTW it seem to be worse turning left.
Old Aug 24, 2015 | 08:33 PM
toobroketoretire's Avatar
toobroketoretire
Are you saying the steering wheel feels jerky when you are at a complete stop and turn the wheels?
Old Aug 24, 2015 | 08:36 PM
vetpace78's Avatar
vetpace78
Yes. I wouldn't say it's severe but it's definitely enough to drive me crazy.
It's like the front wheels hop while turning. Doesn't require any extra force on the steering wheel.
Old Aug 25, 2015 | 02:35 PM
tyancey00's Avatar
tyancey00
could just be air bubbles in the steering pump and hoses. Put it up on jack stands and turn the wheels from lock to lock a few times. this may "burp" the air out of the system...
Old Aug 25, 2015 | 06:55 PM
vetpace78's Avatar
vetpace78
Thanks! I'll try that.
Old Aug 25, 2015 | 07:19 PM
SH-60B's Avatar
SH-60B
And you can adjust the control valve while you're at it, if it needs it, perfect time with the front wheels up.
Old Aug 25, 2015 | 09:09 PM
derekderek's Avatar
derekderek
replace the 2 bushings where the ram attaches to the frame.
To steering skips
