Self-Aligning Rocker Arms
Old Aug 28, 2015 | 03:32 AM
Solid LT1's Avatar
Solid LT1
Originally Posted by DWinTX
Solid, I'm not sure if you are directing this to me or or toobroketooretire, who you quoted. I will acknowledge that I don't know much about Corvettes, or Chevys in general for that matter. That's why I'm asking in the first place.
As I mentioned in the initial post, I've already been down the road of stud replacement, and I understand I'd need to open the pushrod hole as it's been explained by sstocker.
Thanks for the offer of the rocker, that nice of you. But if I'm understanding the info I'm being given here, my problem is the pushrod holes have been worn over time and are allowing the rocker to get off-center. As I understand it, my only option, short of replacing the heads, are guide plates or self-aligning rockers. As I mentioned earlier, I want to upgrade the entire valvetrain after I finish my current project, but I want to keep driving the Vette while I do it. So the SA rockers are just a stop-gap until then. I'll probably rebuild the heads anyway then, so new guides will be installed.
I was directing my comments to the quoted poster that was giving you misinformation.....not you. You need to check you push rod passages in your cylinder head for wear......I doubt the passage has opened up and until you decide to go the a guide plate/threaded rocker stud set up like used on LT-1 motors you shouldn't open up any push Rod holes in your heads. The early Vettes and 67-69 Z/28 motors didn't use guide plates they came about on 1970 LT-1 motors, your L-46 did not have guide plates. The head can be easily checked and compared to an adjacent cylinder for push Rod fit, given the surface area of the slot, I doubt it has opened up. I think you should check the push Rod for straightness by rolling it on a flat surface and if every thing checks out....put it back together like it was from GM. I use a little #680 locktite on press fit rocker studs when I replace them.
I have worked on motors for 40 years now and have seen cut studs more than once, it is not a rare occourance and I've never come across a cylinder head with a drastically loose pushrod passage causing the stud failure. The rocker studs can be easily replaced by stacking washers up and pulling them out with their own threads, you have to be careful that the replacement stud is properly aligned before driving it back into the hole and make sure to clean the hole of all objects/fluids.
Old Aug 28, 2015 | 04:52 AM
BOOT77's Avatar
BOOT77
I'd check all pushrods like said ^^^^ and the rockers, they could be the slop. I'm not a fan of oem press-in studs and from my experience once you start pulling them and then pin them to stop it, then they bend. ARP screw in studs are much better. Still idk bout how you feel on modding your 70, I have no problem changing my common 77. Heads can always be swapped out and back.
Also I sometimes forget that c3's once had decent power so I'm not even sure about the cam specs of your engine.
Old Aug 28, 2015 | 06:52 AM
toobroketoretire's Avatar
toobroketoretire
Originally Posted by Solid LT1
You know little about Corvettes and are demonstrating it here. The picture shows a 186 casting# head, these were used interchangeably on most 4bbl 350 Chevy motors and can be found in 1.94/1.5 valve, and 2.02/1.6 valve configurations...they are also used on Z/28 motors. The head in the picture is about 100% a 2.02/1.6 L-46 cylinder head, the rocker arms are "special" "O" type hardened rockers found on HP motors meaning Z/28, LT-1 and L-46 350HP motors. You should check the pushrod hole in the cylinder head for wear, pushrod straightness, rocker arm wear and valve tip flatness. It is not uncommon to find studs with wear slots in them, you can get a replacement stud in STD or oversize fitment from a auto machine shop. If the rocker is shot PM me, I might have one or two spare "O" rockers around my shop, they are decent parts.
DO NOT put a self aligning rocker on your motor if you don't open up the push rod opening in the cylinder head, it can cause misalignment and valve failure....even possibly dropping a valve into the cylinder. I personally don't care for the later self aligning rockers they cause more guide wear than the earlier hardware.
As I have reconditioned at least 1000 small block cylinder heads in my lifetime I would bet I know a LOT more about them than you'll ever know. The only small block heads that ever got the push rod guide plates were the 2.02" X 1.60" heads because they used a wider 1-7/8" valve spacing which is 1/8" wider than the 1-3/4" lifter spacing. You see, you can't put a 2.02" valve next to a 1.60" valve with the standard 1-3/4" spacing because they'd clobber each other. The #186 casting number head you see in the picture does NOT have the larger 2.02" X 1.60" valves but rather the smaller 1.93" X 1.5" valves because the 2.02" X 1.60" valves REQUIRED guide plates because of their 1/8" wider spacing. Sorry but you're dead wrong.
Old Aug 28, 2015 | 10:14 AM
DWinTX's Avatar
DWinTX
Solid, I will check all of the pushrods for sure. Last night, I started pulling each rocker one at a time. Only got through four as I ran out of time, but I found another stud that has a slot developing. I did use the stacked washer method to remove the other one so I'm familiar with the process. I also put the pushrod from the valve with the slotted stud against a straight edge and found a little daylight showing. It was minimal, but it wasn't perfectly straight either.
Several of the rockers are like the one in the picture, cocked off to the side of the valve tip to some degree or the other. I know logically that millions of GM small block motors have traveled billions of miles with these stock valve trains, but this just seems unstable. Especially given my nature to rev my engines.
How should I measure the pushrod holes? None of them show blatantly obvious wear, but maybe a couple thousandths make a difference? I can measure the width of the holes or the side-to-side play at the top of the pushrod, but I'm not sure what they should be.
Maybe the slop is in the pushrods and rockers, as you mention. You mentioned that these are special hardened rockers (with the "O"). Will the stock-style aftermarket replacements work? Like these:
http://www.summitracing.com/parts/su...make/chevrolet
http://www.summitracing.com/parts/cc...make/chevrolet
Boot77, though I plan to keep this car relatively stock, I don't mind modifying a few internal engine parts to make it last longer, especially the valvetrain. This engine does have good power, not like the later smog/low compression motors. I have a couple of those too, and there's quite a difference.
toobroketoretire, I don't know what to tell you man. I have found several references on the web that the 3927186 heads had the 1.60/2.02 valves. Here's one:
http://gearheadgeek.com/ghgj/index.p...head-casting-s
And as I mentioned earlier, I measured the spacing myself, 1-7/8". And these have never had guide plates. The stud bosses are not machined.
Old Aug 28, 2015 | 12:12 PM
Barry's70LT1's Avatar
Barry's70LT1
In 1970, the L46 DID have 2.02" X 1.60" valves and DID NOT have guide plates.
In 1970, the LT-1 DID have 2.02" X 1.60" valves and DID have guide plates.
Old Aug 28, 2015 | 01:27 PM
bluedawg's Avatar
bluedawg
A while back I had a rocker slide off the valve on my 70 L46 350 because it had worn a notch in the stud. Fortunately, it happened while the car was idling in the driveway so no serious damage was done, just had to replace the stud and bent pushrod.
Since then I've been keeping an eye on those studs to make sure no others end up in the same condition. I tend to drive my cars hard (high revs) and I'd hate to have the same thing happen at 5000 RPM. I noticed that a couple of the rockers seem to not be centered on the valve tip. In the picture below, you can see one of them. The rockers do seem to have a little side to side movement, which I don't think is good at high RPM. I'm not real knowledgeable on GM engines, most of the engine work I've done has been on Mopars. Even stock Mopar engines have shaft mounted rockers and they can't get sideways like this, so maybe it's normal, but it scares me.
I have decided that at some point I'm going to switch to screw in studs, solid roller cam/lifters and roller rockers, but that's probably a year away.
I have another engine at the machine shop right now and was asking the owner yesterday about the cost of machining for the studs. He said that until I'm ready to do it, I might check to see if later SBC rockers that are self-aligning may work. I guess these came on late 80's-up 350 engines and have indentations on the rocker tip for the valve tip to sit in. They seem to be available pretty cheap. Can I use these on mine until I get the shaft mounted rockers?
If i were going to stay with the original head I'd install screw in studs, open the push rod slot's and use guide plates as was mentioned already ecspecially since you want to swap to a solid roller camshaft which between the spring pressure's and the aggresiveness of the camshaft would probably pull the studs, but since you want to swap to a solid roller have you thought about upgrading heads to a good set of aluminum which would be set up in that manner and work better with the camshaft upgrade.
Old Aug 28, 2015 | 02:06 PM
derekderek's Avatar
derekderek
it isn't the rocker arms, studs, or guide plate-slots. you have a bad valve guide. the valve stem is flopping around and pushing the rocker off the tip...
Old Aug 28, 2015 | 05:08 PM
DWinTX's Avatar
DWinTX
Thought about the aluminum heads, but I'm not looking for big HP gains for this car. I have a couple other ones for that. If I can ever get them built anyway. I mainly was wanting to do the valvetrain update for reliability more than power. Of course, if the new cam makes it faster, that won't bother me! This car is already pretty quick, but every time I wind it up it scares me knowing whats going on under those rocker covers.
Old Aug 28, 2015 | 05:09 PM
DWinTX's Avatar
DWinTX
Oh, no! Another reason to look for! I've got my work cut out for me figuring out this one.
Old Aug 28, 2015 | 06:42 PM
SH-60B's Avatar
SH-60B
For reliability stick with a hydraulic cam, why use a solid cam if max power isn't the objective?
Old Aug 28, 2015 | 06:56 PM
derekderek's Avatar
derekderek
you can probably grab that valve spring and rock valve side to side...i have a set of Dart sportsmans and one rocker was falling off side of valve. i couldn't believe how much that valve could wiggle. and this is a boat engine. no real amount of running time compared to a car engine.
Old Aug 28, 2015 | 08:06 PM
DWinTX's Avatar
DWinTX
Well, I did say I wasn't going for big power gains. My main objective was going to be two things. One, stabilize the valvetrain for frequent high-rpm use, and two, basically change this to an LT-1 engine. I've always wanted an LT-1 but can't afford it. This engine already has a Performer RPM manifold, which I'm hoping is close to the LT-1's. If I add the solid lifters and an LT-1 cam (or some modern equivalent), I was hoping to get the LT-1 feel.
Plus I just like solid lifters.
Old Aug 30, 2015 | 03:35 PM
  #33
c3_dk's Avatar
c3_dk
I have 2 HW 1969 Corvette L46 engines, both are very originale, both engines have 186 heads.
Both set of heads has 2.02 x 1.60 valves, non of them have guide plates.
Old Aug 30, 2015 | 03:42 PM
  #34
Big2Bird's Avatar
Big2Bird
But have you done 100000000's of valve jobs?
Old Aug 30, 2015 | 03:45 PM
  #35
c3_dk's Avatar
c3_dk
I've done some, here is my valve grinder
Old Aug 30, 2015 | 04:29 PM
  #36
Barry's70LT1
What a nice machine to own, gets the job done !!
Old Aug 30, 2015 | 07:37 PM
  #37
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Isn't this fun??
I can't begin to count the number of original 2.02/1.60 heads I've seen over the years without guideplates. Never saw a 327 with them from the factory and quite a few had big valve heads. Same with early Z-28's.
Not too wild about carving on the heads to convert to valve guided rockers either. First...you better have some good valve stem tip above the retainers or you're going to be pressing on keepers/retainer instead of the tip.
I'd be looking real close at the valve/guide etc. to see what has moved. They weren't mega-precision from the factory and the ball fulcrum rocker allowed for some inconsistency. Maybe this one was out of whack for years and finally wore into the stud?
I wouldn't spend the money to convert a set of 186 heads to guideplates and whatever else they needed. Might as well buy some good ehads and be done with it and make some power.
Yep...I've done some headwork over the years too. Also have my own Sioux valve machine and seat cutter equipment at home...but the Serdi stuff is awful nice! Hard to tell in the above video because I wasn't standing there...but I'd have left as much meat on the valve as possible since the seat area was already cleaned up and do that last final part with a 30* back cut. As you cut valve...the diameter decreases and the seling areat moves closer to the edge. Then when you cut the seat..the hole gets larger and moves the sealing area even closer out to the edge. Leaving as much on valve as possible increases flow, leaves material on valve so it won't sink into the seat as far (and hurt flow even more) and all is good.
JIM
