Overheating over 55 MPH
Old Aug 30, 2015 | 12:08 PM
Kevin F's Avatar
Kevin F
7th Gear
Default Overheating over 55 MPH
I have a C# 1977 Corvette with a dewitts alum radiator with twin fans NO FAN ON ENGINE, It overheats with A/C on only, in city temp is fine about 190 with a 180 t stat. 5.7 liter 20 0ver with 10 to 1 flat tops 268 cam alum heads. Can anyone help
Old Aug 30, 2015 | 12:25 PM
OMF's Avatar
OMF
Check to see that the lower air dam is in place...it diverts the air up into the rad.....it's common to be missing. Make sure all the foam seals are in place around the rad. Check to make sure the front of the rad is clean,use a vacuum to clean it out. Is there a shroud around the rad as well as the electric fans? If not the corner parts of your rad aren't doing all they could be towards cooling.
Old Aug 30, 2015 | 12:44 PM
Kevin F's Avatar
Kevin F
7th Gear
Air Dam? is that the spoiler done mean to sound stupit my first Corvette Does not have the gaskets around radiator and shroud is not in place fans came as a kit with radiator didn't know I still had to run shroud
Old Aug 30, 2015 | 03:07 PM
toobroketoretire's Avatar
toobroketoretire
Sigh, another electric fan and overheating story. Are the twin fans enclosed in a large shroud that covers the whole face of the radiator? If not only a small portion of your radiator is doing any cooling. The original radiator used a large fan shroud for a reason so taking that shroud off and not using an equivalent shroud is a huge mistake.
Old Aug 30, 2015 | 03:14 PM
'75's Avatar
'75
At highway speeds the fan is doing very little for cooling "if"; the lower air dam is in place, the seals around the radiator are in place and the seal from the core support to the hood. Basically seal it up so any air up front has to be forced through the radiator and does not go around it.
Check timing also, retarded timing will make it run hot.
Old Aug 30, 2015 | 04:08 PM
REELAV8R's Avatar
REELAV8R
Check to see that the fans are blowing in the right direction. Which fan set up do you have?
Old Aug 30, 2015 | 04:21 PM
BLDun's Avatar
BLDun
Not sure that I have a "remedy" per se for your overheating. However, if the dual fans you have came with the DeWitts radiator you will not need any further sealing around the radiator. When I installed mine I had already purchased the sealing kit but could not see how it would fit properly so I call DeWitts. Tom himself told me that it was not necessary since the dual fan setup I had covered the entire span of the aluminum radiator and for me he was correct. I didn't use any of the sealing foam kit and mine never runs over 180. While there are always purists that curse the electric fan scenerio the fact is that if it were that bad all of the newer cars would still be running a mechanical fan with a fan belt. There are other things to check to see why you are running hot but according to DeWitts it isn't due to the packing around the radiator.
Old Aug 30, 2015 | 05:20 PM
Kevin F's Avatar
Kevin F
7th Gear
I am running the new Dewitts Rad with the Spal fans that was purchased as a combo kit
Old Aug 30, 2015 | 05:46 PM
Kevin F's Avatar
Kevin F
7th Gear
timing is 36deg @2500 rpms with vac advance plugged off
Old Aug 30, 2015 | 05:48 PM
OMF's Avatar
OMF
is this the setup you have? If so you shoud be fine, the problem is probably the spoiler/air dam.
http://cdn.shopify.com/s/files/1/016...g?v=1357674939
this is the Airdam/Spoiler
https://www.paragoncorvette.com/imag...large/7445.jpg
Old Aug 31, 2015 | 06:12 PM
TimAT's Avatar
TimAT
I had a slight problem when I first got my 69. Never overheated, just got warmer than I like when I was on the highway. Pulled the front license plate bracket and now it never sees 200*. No a/c, BB, 12.5 compression and plenty of timing with real good gas.
You may be required to run a front plate- Technically I am too, but running year of manufacture plates, most of the LEO's that would know are long since retired..
Someone said check the seals around your radiator- good advice. Also check the top of the radiator between it and the core support. I had a 77 and used a piece of a pool noodle to seal it up.
Old Aug 31, 2015 | 06:28 PM
mrvette's Avatar
mrvette
HI Tim,.....the OP needs to drill about 3 3/16 holes in the flange of the stat.....because to make up for the smaller diameter of the modern stats.....a 180 stat opens at 180 ok but the flow is restricted to the 'NEW' standard diameter smaller opening....typical EPA......
Old Sep 1, 2015 | 07:37 AM
toobroketoretire
And the goofy C3 myths continue..........................
Old Sep 6, 2015 | 01:20 PM
Kevin F's Avatar
Kevin F
7th Gear
I got to the problem seems like only when the A/C is running its runs hot checked my pressures 215 head all seals around radiator is new and new air dam once I turn the A/C off you can eatch the temp drop 180 t stat both fans run with the A/C on
To Overheating over 55 MPH
