79 no start
Old Aug 30, 2015 | 01:12 PM
AleroGLS's Avatar
AleroGLS
8th Gear
Default 79 no start
Ok I've been beating my head against a wall I've set the timing a few times now I've got spark back but for some reason It just won't start it try's and spit spudders and backfires through the carb it has a new distributor that I bench check and works good none of the valves look like they are sticking I'm lost can some one help
Old Aug 30, 2015 | 01:18 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
How did you set the timing w/o it running?
Old Aug 30, 2015 | 01:21 PM
AleroGLS's Avatar
AleroGLS
8th Gear
I guess I should have re worded that I set cylinder one to tdc to get initial setup and I'm having these problems
Old Aug 30, 2015 | 01:27 PM
Jud Chapin's Avatar
Jud Chapin
Did it run okay prior to installing the new dist? If it did, I'd say your problem points to one of timing if the dist is good.
Old Aug 30, 2015 | 01:29 PM
AleroGLS's Avatar
AleroGLS
8th Gear
No when I got it it had no spark at all my coworker said when it died he hit the throttle and heard a mettalic sound and as stated I got spark back it just keeps spitting through the carb
Old Aug 30, 2015 | 01:33 PM
Jud Chapin's Avatar
Jud Chapin
For starters, I'd double check the plug wires to be sure they're installed in their proper firing order.
Old Aug 30, 2015 | 01:34 PM
AleroGLS's Avatar
AleroGLS
8th Gear
Ok is there anything else in peticular I should look for
Old Aug 30, 2015 | 01:39 PM
Jud Chapin's Avatar
Jud Chapin
If it wasn't running when you got the car, it could be a host of possibilities. Is it getting proper fuel and how old is it (fuel)?
Old Aug 30, 2015 | 02:57 PM
toobroketoretire's Avatar
toobroketoretire
It's backfiring because the timing is too far advanced.
Old Aug 30, 2015 | 03:19 PM
'75's Avatar
'75
Could be ignition timing, could also be that the timing chain has jumped time. How many miles on the engine?
Old Aug 30, 2015 | 03:40 PM
Big2Bird's Avatar
Big2Bird
My guess. He is 180* out.
Old Aug 31, 2015 | 11:44 AM
AleroGLS's Avatar
AleroGLS
8th Gear
Ok I got the wires straightened out and now it's acting like no spark again any ideas distributor is good and has battry voltage at the distributor. It's definatly getting gas you can see that when you open choke plate and I have it set of cylinder one tdc on compression stroke is there something I'm missing like mabey it jumped a tooth in the chain?
Old Aug 31, 2015 | 05:31 PM
AboveTheLogic's Avatar
AboveTheLogic
Pull a plug, hold it to ground using an insulated set of pliers, have someone crank the engine, see if there is any spark. If there is spark, then you have a timing issue. If no spark, that changes things.
Old Aug 31, 2015 | 05:50 PM
derekderek's Avatar
derekderek
i agree. you set #1 at tdc, but you were where intake just opening and exh just closing. #6 should be firing at that point...
Old Sep 1, 2015 | 10:43 AM
AleroGLS's Avatar
AleroGLS
8th Gear
Whe I set it at tdc I had v/c off intake valve had just closed so I moved it a little more exhaust valve started to open is I moved it back to zero setting in the timing tab is that wrong?
Old Sep 1, 2015 | 11:15 AM
AboveTheLogic
Here's an old trick my grandfather taught me.
  • Pull the spark plug, leave the wire connected.
  • Shove a small part of a clean rag into the spark plug hole, just enough to seal the hole.
  • Ground the spark plug, holding it with some insulated pliers.
  • Have someone crank the engine.
  • Watch for the spark on the plug, it should happen pretty much at the same time as the rag pops out of the hole, which you should be able to hear.
You'll get a pretty good idea if you're off 180* and can confirm at the same time that you have spark.
I suppose if you have a timing light, you could just use that instead.
Old Sep 1, 2015 | 11:33 AM
derekderek's Avatar
derekderek
Absolutely. You are now SURE you are 180 out. When int and exh are both just open-closing is 180 out. 6 is firing at that point.
To 79 no start
Old Sep 1, 2015 | 11:38 AM
AleroGLS's Avatar
AleroGLS
8th Gear
Ok now I know when your at tdc on compression stroke both valves should be closed so I just rotate it 180* from current setting and reset the distributor to that and I should be ok right
Old Sep 1, 2015 | 04:16 PM
derekderek's Avatar
derekderek
Pull dist wherever it is and rotate it 180 and put back.
Old Sep 10, 2015 | 10:20 AM
AleroGLS's Avatar
AleroGLS
8th Gear
Thanks for the help everyone after I set timing she will be done runs now
