Best side pipes?
Old Aug 31, 2015 | 05:05 PM
vannmike's Avatar
vannmike
Default Best side pipes?
So car is getting painted, when it gets back, time to put the motor in. Looking for advice on side pipes? It's a 77. I know side pipes are anti performance, but what kind are the best for performance. It's a blue print small block 396. And I have to buy headers specifically for side pipes right?
Old Aug 31, 2015 | 05:17 PM
keithinspace's Avatar
keithinspace
Sidepipes aren't anti-performance.
Some sidepipe BAFFLES are anti-performance.
Very generally speaking, the louder the baffle, the less restrictive the sidepipe, the better the performance. That's a very general summary, though.
I run STS baffles and they match my solid roller engine very well. They aren't too loud at cruise, but SCREAM at full throttle. A good scream.
Old Aug 31, 2015 | 05:35 PM
vannmike's Avatar
vannmike
Hmm. Remind me what a baffle is? And for maximum performance, what about no baffle?
Old Aug 31, 2015 | 05:49 PM
AboveTheLogic's Avatar
AboveTheLogic
The baffle is the muffler insert that goes in the large main pipe that runs from the header collector to the rear edge of your door. Some kits ship a pipe with no insert at all and that would be absolutely loud just like running open headers.
I bought a Doug's kit and chose the muffler/baffle/insert/whatever you want to call it that was in the middle of the 3 different noise/flow options. It is still a bit louder than I'd like but I don't know anyone with sidepipes that I could have called to listen to what its like. Videos online don't really paint the picture as far as sound goes.
Old Aug 31, 2015 | 06:00 PM
vannmike's Avatar
vannmike
Do you have a part number, and a picture?
Old Aug 31, 2015 | 06:05 PM
AboveTheLogic
Summit part numbers for what I'm running:
DOU-D380-B - Headers
DOU-D930-B - Side Tubes
DOU-D950 - Slip-in muffler
Old Aug 31, 2015 | 06:28 PM
jkippin's Avatar
jkippin
not sure if you like the looks of the OEM style but you can get them in different pipe diameters from Sweet Thunder. I am running a set on mine they are 2.5 pipes not too obnoxious till you stand on it they do make chambered mufflers too. John was great to deal with there.
Old Sep 1, 2015 | 12:21 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I have Maximizer Stainless Sidepipes with HOOKER Maxflow inserts (part 21046) and based on dyno tests and track results, the maxflow mufflers give you close to open header performance, so, with that setup, you certainly will have more HP than with regular exhaust.. I just went from regular exhaust to the Maximizers and Maxflows and I can feel that the car has more power with this setup.
Cost is fairly low.. You can get the Maximizers on Ebay for $699 + $100 shipping.. Maxflow mufflers are about $178.. So, for about a grand, you have a nice looking setup that gives you great performance!
Old Sep 1, 2015 | 12:23 PM
AboveTheLogic
Man, that is really, really nice '68
Old Sep 1, 2015 | 12:41 PM
GrandSportC3
Thanks.. I just got it in June... Had less than 58k original miles on it. Other than the side pipes, the car was just the way it is now.. I love the paint scheme. I probably wouldn't even have looked at the car if it didn't have the stripe.. It makes it different.. I also love the T-handle hurst shifter.. I had the same one on my first C3 ever.... over 20 years ago..
Old Sep 1, 2015 | 12:42 PM
Street Shaker's Avatar
Street Shaker
Ran with baffles and did not like the way car sounded with them at all, switched to Hooker Maxflow and absolutely love the sound !
Here is couple videos with Hooker Maxflows.
Old Sep 1, 2015 | 12:51 PM
GrandSportC3
https://youtu.be/zpZBcfqBNaM
https://youtu.be/buCU4GCFKNI
Another vote for the Maxflows...
Old Sep 1, 2015 | 01:08 PM
vannmike's Avatar
vannmike
Maximizer stainless steel side pipes and hooker max flow inserts. What about mounting hardware. Was all that with it. Forgive me, I have zero experience with side pipes.
Is this it?
http://m.ebay.com/itm/151793670531?fits=Model%3ACorvette
As nd mufflers?
http://www.jegs.com/i/Hooker/520/210...tmKBoC77fw_wcB
Old Sep 1, 2015 | 01:42 PM
GrandSportC3
Is this it?
http://m.ebay.com/itm/151793670531?f...del%3ACorvette
As nd mufflers?
Yes, those are the pipes and the mufflers.. There is close to no power loss from those mufflers and they sound AWESOME!! The Maximizer side pipes are a great value.. I'm happy with mine so far!
Installation is fairly straight forward for anyone with moderate mechanical skills.. Probably a 4 on a scale from 1 to 10 where 10 is the most difficult job. The only challenging part is to jack up the car to at least 20 inches (frame to ground).. I had to get extra high 6 ton jack stands to get the car that high and use 2 screwed together 2 x 4's on top of my jack to get the car high enough as my jack would only go to 17 inches.. If you get the car high enough, it's fairly easy to get the pipes up into the engine compartment.
Old Sep 1, 2015 | 01:54 PM
redvetracr's Avatar
redvetracr
isn`t it about time you let the air out of your air shocks?
Old Sep 1, 2015 | 01:57 PM
GrandSportC3
I know.. I need the longer spring bolts.. Since I installed the composite spring, the car sits way too high in the rear.. I need the 10 inch bolts.. (currently 8 inch bolts)
Old Sep 1, 2015 | 03:02 PM
AboveTheLogic
I need to do that too, my car sits a bit too high in the rear but I'm reluctant to install bolts that would hit the ground in the event of a flat tire.
To Best side pipes?
Old Sep 1, 2015 | 03:06 PM
GrandSportC3
True.. that's a concern. I have to measure to see how long of a bolt I could use without hitting the ground.
Old Sep 1, 2015 | 03:08 PM
AboveTheLogic
I suppose you could always put a caster wheel at the bottom of the bolt just in case
Old Sep 1, 2015 | 03:11 PM
GrandSportC3
