Cooler Plugs? Help
Old Aug 22, 2002 | 04:22 PM
VETDRMS's Avatar
VETDRMS
Default Cooler Plugs? Help
I am running some 041 64cc Heads with compression ~9.6:1
I was advised to run a cooler plug with this combination,
but my plugs seem to be getting fouled/not working...
Can i use a standard heat plug with this combination, or should
i continue to use the cooler plugs? I'm going to buy some in about an
hour, so a quick insight would be appreciated. Thanks :cheers:
Old Aug 22, 2002 | 04:31 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default Re: Cooler Plugs? Help (VETDRMS)
are you getting detonation? if not, i would think you would want a hotter plug to burn off the crap. what kind of fouling are we talking about here? over rich fouling? oil burn fouling?
i don't proclaim to be an expert but i would think that if your getting fouling the last thing you would want to do is cool the plugs more. just my $.02
