Brake problem
Old Sep 16, 2015 | 07:27 PM
DUB's Avatar
DUB
Originally Posted by RMJ11949
With the booster disconnected shouldn't my brakes work unassisted with a hard pedal?
YES...with NO VACUUM going to your brake booster....you should have to stand on the brakes to get the car to stop and the pedal should be hard. It would be like trying to stop a freight train.
DUB
Old Sep 19, 2015 | 07:33 PM
RMJ11949's Avatar
RMJ11949
UPDATE:
Still not fixed.
I removed all the brake pads and inspected the calipers, found one with a frozen piston and replaced caliper. Bled system again.
NEW: While kneeling beside car with engine running I can here a "whooshing" sound when I depress the brake pedal. My exhaust is fairly loud and didn't notice it while sitting behind the wheel. It does not seem normal. Makes me suspect booster even more.
HELP: Can someone who owns a 1977-1982 try this on their car and let me know if they hear a "whooshing" sound when pressing brake?
THANKS!
Old Sep 19, 2015 | 09:39 PM
Oldguard 7's Avatar
Oldguard 7
UPDATE:
Still not fixed.
THANKS!
Do you now have a firm pedal? I had a sound like a rush of air when I would press on the brake pedal prior to replacing my master cylinder and rear brake calipers/hoses a couple of weeks ago. Brake light was on and pedal went to the floor also. After I made said repairs and bled the system I no longer have that rush of air sound when I push the brake pedal. Can you post a vid so we can hear what it sounds like.
Old Sep 20, 2015 | 12:11 PM
toobroketoretire's Avatar
toobroketoretire
UPDATE:
Still not fixed.
THANKS!
If you have a spongy pedal you still have air in your system. With the master cylinder lid OFF open each of the bleeders one at a time for maybe 15 minutes until ALL the air is purged. Just be sure to keep the master cylinder full during the lengthy bleeding process so you don't get more air into the system.
Old Sep 20, 2015 | 07:39 PM
DUB's Avatar
DUB
The 'whooshing' sound is NORMAL....it should do that...where you can hear it from under the dash when the engine is running...supplying vacuum to the booster...and then pressing on the brake pedal. It is the build up of vacuum being released as designed.
The volume of the sound may also be attributed to the rubber seal and foam at the back of the booster area. I have seen this material worn out and or missing and allowing the sound to be greater in some cars.
DUB
