Weight loss stories
Old Aug 23, 2002 | 12:15 AM
73 LS-4's Avatar
73 LS-4
Default Weight loss stories
Which diet plan has worked best for your vette :jester Actually I was wondering who has originally weighed their car and then tried to remove weight and what they got down to.
:cheers:
Pat Kunz
Old Aug 23, 2002 | 12:57 AM
gkull's Avatar
gkull
Default Re: Weight loss stories (73 LS-4)
3084 on the scales. it was years ago. Since then I've added 9.90 legal roll cage and went back to a steel rear spring. My minuses are aluminum heads, water pump, radiator, and a 12.6 pound sparco seat with five point belts.
My car is gutted of all other stuff. On this forum some how his car is 2800 ish. I couldn't get any lighter. Just click on my sig and see what i've done
My original door sticker said something like 3485 or something like that and i had 500 pounds of stuff in boxes for a 79. the factory lies so much. The 79 L-82 was such a pig car
Years ago i was into Auto-X and you have to think about racing against the trailer queens. I was in BSP all road racing tires. Then the 86 Vette was the first year of AntiLock ABS back then. So once your in with the big boys I went for it.
[Modified by gkull, 11:12 PM 8/22/2002]
Old Aug 23, 2002 | 01:12 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
:cheers:
Pat Kunz
I have never weighted my Vettes but I guess that my 68 is approx. 3200 or less....
BTW: My Vette has no spare tire and no accessories!!!
:cheers:
Olivier
[Modified by GrandSportC3, 12:14 AM 8/23/2002]
Old Aug 23, 2002 | 02:15 PM
tworottiedogs's Avatar
tworottiedogs
I weighed in at 3500 with me in the car. That puts the car at about 3320 which I think is about normal for a 71 BB.
Old Aug 23, 2002 | 05:15 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
I've been running hard now for the past 7 months or so. So, with me in my vette, she's at least 20 lbs lighter now!!! :D :D :D
Old Aug 23, 2002 | 06:05 PM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
1966 big/block 427 Conv, 3080 LBS., No driver 1/3 tank of gas.................. side exhaust,,,,, think its lighter than under car eXhaust system..........Alum heads, mini starter, mono rear fibergalss spring. no spare or jack & removed entire spare tire carrier assembly... on the pluss side & put on P/S since last wieghed.................however alum water oump goes on this winter........ :smash: :seeya :flag :cheers:
Old Aug 23, 2002 | 07:20 PM
groovyjay's Avatar
groovyjay
Default Re: Weight loss stories (StrayDog)
Mine was 3615lbs before diet, goal is set somewhere around 3000lbs. :crazy:
Old Aug 24, 2002 | 12:51 AM
73 LS-4's Avatar
73 LS-4
I guess I should mention what I did for weight savings: Aluminum intake, no spare, no jack, no spare carrier, no A/C, No smog equipment, Aluminum Rims, and Headers. I guess my 73's weight at about 3575lbs with a full tank of gas.
:cheers:
Pat Kunz
Old Aug 25, 2002 | 09:51 AM
StrayDog's Avatar
StrayDog
73 LS4, wieghtd my 66 on the scale at New England Dragway, you will never actually know until you put youe Vette on a scale.........The Dog :seeya
Old Aug 25, 2002 | 12:18 PM
73 LS-4's Avatar
73 LS-4
Your right StrayDog :yesnod: , I need to get that done someday, becouse I'm real curious as to what it actually weighs. You mid year guys are lucky, your cars start off a whole lot lighter then most of the C3's, 3000lbs with a big block is excellent.
:cheers:
Pat Kunz
Old Aug 26, 2002 | 10:58 AM
norvalwilhelm's Avatar
norvalwilhelm
Had my 75 weighed Friday with a full tank of gas. 3592 lbs.
Old Aug 26, 2002 | 01:45 PM
fireball's Avatar
fireball
Not sure where I started...
But with these mods:
headers: -- weight
alum intake: - weight
no spare: - weight
alum driveshaft: -weight
Steel bellhousing: +++weight
I'm at 3,640lb with 1/4 tank gas.
Old Aug 26, 2002 | 03:45 PM
73 LS-4's Avatar
73 LS-4
Default Re: Weight loss stories (fireball)
Hey fireball, what's the aproximate weight of the steel bellhousing, and is that with or without A/C?
:cheers:
Pat Kunz
Old Aug 26, 2002 | 05:41 PM
VetteNut72's Avatar
VetteNut72
I just got my '72 running after 2 years in my garage. I added another 100hp to the stock ZZ4 and I lost 125 pounds for my health. How much horsepower did it take to push that extra 125 pounds around? Should feel like I gained 150hp :lol:
To Weight loss stories
