Shock mounts appear bent
Old Sep 13, 2015 | 06:36 PM
Joebrick's Avatar
Joebrick
Default Shock mounts appear bent
Just knocked loose my shock mounts and it appears they are bent.
Before I order new ones, I assume they should be "square" trailing arm to shock...is that correct? Don't want to buy new ones if they are supposed to be offset.
How would these bend like this on the car?...they sure seem stout.
Old Sep 13, 2015 | 07:37 PM
DUB's Avatar
DUB
They do have a funny look to them even when new.
The main reason I replace them is IF the splines on the main shaft...that you knocked out are worn...so when I go and put it through the bearing support housing and it takes NO EFFORT to seat it...due to the splines are worn down....I REPLACE IT!
YES..I know that the castle nut gets tightened quite a bit....and 'thinking' that the flat spot on the threaded shaft does anything at all in keeping the lower shock mount bolt positioned where it need to be is NOT true. The grade of metal of the main shaft is soft...because IF you whack it with a hammer...you will distort it. SO....thinking that the flat spot is actually going to not give way if it contacts with the flat notch of the bearing support housing....guess again....and do not ask me how I know this FACT!
So it is up to you if you want new ones or re-use what you have.
IF the shaft where the shock absorber is also badly worn, pitted, and just basically crappy looking...I replace it. I have seen some that were really scary looking and just slam ate up!
DUB
Old Sep 13, 2015 | 09:07 PM
Joebrick's Avatar
Joebrick
That's a great help. Both mounts are shaped the same so I am thinking this may be normal. If they fit up loose when they go back in I'll replace them as you said.
Going with heim joint struts on this job.
Old Sep 14, 2015 | 07:13 PM
DUB's Avatar
DUB
VERY GOOD CHOICE!!!!
DUB
To Shock mounts appear bent
