78 l82 engine compartment heat
Old Sep 18, 2015 | 12:49 PM
Jplotts's Avatar
Jplotts
1st Gear
Default 78 l82 engine compartment heat
Recently purchased a 78 pace car. I am having an issue with heat in the engine compartment. After a hour or so of driving it gets so hot the module goes crazy and it start miss firing and stalls. After sitting for a few it's fine. I'm also having issues with the starter getting so hot it won't crank. I plan to restore this car as stock as possible just looking for some tips before I start my projects thanks.
Old Sep 18, 2015 | 01:17 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If you're referring to the ignition module, this is a fairly common problem. I'd replace it with an OEM. Re starting problems, have you had the battery load tested? If ok, suspect the starter. These cars will generate a lot of heat. If the engine temp is in normal range, I'd say you're okay.
Old Sep 18, 2015 | 01:21 PM
Bloodzone's Avatar
Bloodzone
A heat wrapped mini starter is a good investment. If your having vapor lock or fuel boil issues wrap your fuel line and install a carb spacer to block heat soak. Make sure the front rubber air dam is present. Mine was missing when I purchased my 79.
Old Sep 18, 2015 | 03:24 PM
Alwyn678's Avatar
Alwyn678
[QUOTE=Bloodzone;1590520336]A heat wrapped mini starter is a good investment. If your having vapor lock or fuel boil issues wrap your fuel line and install a carb spacer to block heat soak. Make sure the front rubber air dam is present. Mine was missing when I purchased my 79.[/QUOT
Good advice
Old Sep 19, 2015 | 03:51 AM
hunt4cleanair's Avatar
hunt4cleanair
It must not be stock...presently?
Old Sep 19, 2015 | 07:37 AM
sstopczy's Avatar
sstopczy
What is your timing set at? 4 degrees as indicated in manuals or on sticker under the hood is too retarded and will cause the engine bay to get very hot. I had the choke fixed on mine once and the guy reset the timing to 4 degrees and I couldn't believe the heat. I set it between 12-14 based on Lars recommendations and there was a significant temperature drop. Just a thought before you go buy other parts and heat wraps.
Old Sep 19, 2015 | 09:36 PM
7T1vette's Avatar
7T1vette
If you have a 'real' GM starter, a 'no hot start' problem is almost always somewhere other than the starter, itself. Could be power or ground wires; could be starter solenoid; could be neutral start switch or ignition switch; could be fusible-links at starter solenoid.
Very unlikely to be the starter itself, unless the internal brushes are 'toast' (and they can be replaced easily and for low $$).
P.S. Your late 70's engine operates at temps just below the boiling point of water. Just how cool do you think the engine compartment on a Corvette should be??
Old Sep 20, 2015 | 12:04 PM
toobroketoretire's Avatar
toobroketoretire
The no-crank because of a "hot starter" is a myth that got started many years ago and is still believed today. High heat will affect the solenoid somewhat but the aluminum ground cable will affect the hot cranking a LOT because of super-high resistance. Trash your OEM aluminum block ground cable and get a decent #4 copper cable with copper eyes. In the summer months an engine compartment temperature of 200 degrees is normal so its nothing to worry about.
Old Sep 20, 2015 | 12:11 PM
Big2Bird's Avatar
Big2Bird
Again, this "myth" was addressed by a GM service bulletin. This "myth" was confirmed by GM engineers.
Just because you had a separate issue does not preclude a fact from fiction.
Old Sep 20, 2015 | 12:17 PM
Jud Chapin's Avatar
Jud Chapin
Been there, done that.
To 78 l82 engine compartment heat
