door spring install on 68 convert
Old Sep 21, 2015 | 12:37 PM
ronarndt's Avatar
ronarndt
Default door spring install on 68 convert
I watched the Willcox video for installing the door spring with the hinge in a vice, off the car. I have the tool they recommend, but with the door actually on the car, space is limited and I am having trouble getting the top part of the spring in place so I can lever the bottom part. Top of spring hits part of the door frame so it will not go in place. If I grind about 1/4 inch off the end of the top curve to get clearance, will the spring stay there or will it slip out? I really do not want to take the door off to get the spring in place. Suggestions? RA
Old Sep 21, 2015 | 01:49 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you remove more meet from the spring to get more clearance you'll be fine as long as you get the spring end in that D slot. Once it's in place the D slot is what holds it in place.
Willcox
