No lights and no start
Old Sep 22, 2015 | 04:12 PM
kaman's Avatar
kaman
Default No lights and no start
I started my 1968 roadster and while it was warming up it died, I have power to the starter, turn the key and nothing. The lights will not go on either, the door ajar buzzer is working but nothing else, any suggestions? does this have a fuse?
Old Sep 22, 2015 | 05:47 PM
toobroketoretire's Avatar
toobroketoretire
It could simply be a real bad connection at the battery.
Old Sep 23, 2015 | 11:09 AM
kaman's Avatar
kaman
Anybody? horn, warning buzzers work, power to the starter and alternator but nothing else. fuse box has no power
Old Sep 23, 2015 | 11:54 AM
Ironcross's Avatar
Ironcross
clean the ground cable to the frame under the car
Old Sep 23, 2015 | 12:47 PM
kaman's Avatar
kaman
Clean connection new cable
Old Sep 23, 2015 | 01:09 PM
Big2Bird's Avatar
Big2Bird
I would hold the fusable links at the horn relay suspect.
Old Sep 23, 2015 | 02:41 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Check all four battery cable connectors for corrosion and good connections. Also check all cable insulation for corrosion underneath.
To No lights and no start
