1978 Rear Spring Change
Old Sep 26, 2015 | 08:49 AM
JKubiak's Avatar
JKubiak
Default 1978 Rear Spring Change
My 7-leaf steel spring is in need of replacement with the back end of the car sitting too low and ride a bit rough. I'm thinking of a TRW composite mono leaf spring as a replacement. Wondering which is the better option - the 340 lbs or 355 lbs? I'm also expecting this exercise is going to lead to new shocks. On a budget so trying to upgrade in phases here. Thx.
Old Sep 26, 2015 | 10:33 AM
cagotzmann's Avatar
cagotzmann
Before deciding on the brand of the mono leaf check out the possible problems with ride height. There are a few reports of some units providing a very high ride height. The most common unit without reported problems are from VBP. There may be others but check this out before your final purchase.
I have a complete VBP Street and slalom kit on my 78 with no problems with ride height.
Old Sep 26, 2015 | 02:50 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Sep 26, 2015 | 04:57 PM
Redhook98's Avatar
Redhook98
After lots and lots of forum research, I just ordered the 330-lb spring from VBP. Seems to be the best out there and most widely recommended.
Old Sep 26, 2015 | 06:13 PM
jb78L-82's Avatar
jb78L-82
The 360 VBP composite is the replacement for the gymkhana 7 leaf spring...7 leaf steel spring is the sport suspension spring, 9 leaf for the base suspension cars. I have had my VBP 360 composite on my 78 since 1986 and the car came with the gymkhana suspension...I love mine with Bilstein Sports in the rear and Bilstein HD's in front with my 550 coils. The car is firm but not harsh and handles and rides so much better then the OEM steel spring.
Old Sep 27, 2015 | 09:03 AM
leadfoot4's Avatar
leadfoot4
Originally Posted by jb78L-82
.... The car is firm but not harsh and handles and rides so much better then the OEM steel spring.
Back in the mid-90s, I "went through" the suspension of the '79 coupe that my wife owned at the time (bought new). I installed a VB&P spring, and as you said, it totally transformed the ride. It went from riding like a buckboard, to actually riding like a car!
Old Sep 27, 2015 | 11:25 AM
JKubiak's Avatar
JKubiak
Thx for responses so far. It seems that the VB&P composite is getting the most hits. Decision will be 330lb vs 360 lbs then. Did the spring require the longer 8" bolts or the standard 6.5"?
Old Sep 27, 2015 | 01:17 PM
leadfoot4's Avatar
leadfoot4
IIRC, I used the standard length, but since I did the job about 20 years ago, don't quote me on it. However, my suggestion would be to contact VB&P directly, and talk to their tech line. They'll ask you about the particulars of your car, and recommend a spring rate based on that.
Old Sep 27, 2015 | 11:46 PM
MGB's Avatar
MGB
St. Jude Donor '14
Hey guys. Like JKubiak, I need to change out my rear spring, it just sits low now and rides terrible. I'll change the rear shocks at the same time I change the spring....QUESTION, think it will help with the dreaded "bump steer" problem ??? Thanks
Old Sep 28, 2015 | 01:46 AM
Kid Vette's Avatar
Kid Vette
It will require the 8" bolts which are provided with the spring.
Old Sep 28, 2015 | 01:50 AM
Kid Vette's Avatar
Kid Vette
I think you may be referring to the toe steer problem which is inherent in the C3 rear suspension. The spring will have no effect on that other than the proper ride height minimizes the problem. Inboard halfshaft u-joint should be 1/2" higher than outboard per John Greenwood's recommendation in the VIP series of articles.
Old Sep 30, 2015 | 10:01 PM
EIGHTY's Avatar
EIGHTY
That's what I got a few months ago along with Billstein shocks and it's like driving a different car!
Old Oct 1, 2015 | 07:36 AM
JKubiak's Avatar
JKubiak
Did you choose the Sport or HD shocks?
Old Oct 1, 2015 | 08:37 AM
EIGHTY's Avatar
EIGHTY
I did sports in the rear, but I've heard good things about the HDs as well.
To 1978 Rear Spring Change
