Flasher problems
Old Oct 3, 2015 | 06:18 PM
Robban f's Avatar
Robban f
Now i have compared the old harness against the new
The 2 wires to the flasher was on the wrong spot on the new harness.
As i thought.
But i still spliced it in the front a bit up so i got the correct colour to the lamps.
It´s to tight when the front and engine harness are conected so i couldn´t split the connector, maybe a could but i realised that i probably would damage and make it more worse.
BUT Why does the sidemarker light flash with the ordinary flasher.
If i have no light turned on the flasher and sidemarker flash at the same time, but do i turn on the lights it flashes every other time against the ordinary flasher.
I give up soon
Can it have something to do with the sidemarkers in the rear that have broken lamps?
Old Oct 3, 2015 | 07:37 PM
lionelhutz's Avatar
lionelhutz
They're wired to do that. The bulb is connected between the signal light wire and the running light wire.
Old Oct 4, 2015 | 04:13 AM
Robban f's Avatar
Robban f
Ok thanks! Then the problem is solved😊
Thanks for all the quick and good answers from everyone.
This is a very nice forum!!!
