Helmet for drag racing?
Old Oct 2, 2015 | 06:19 AM
jboweriii's Avatar
jboweriii
Default Helmet for drag racing?
I have a 1969 and are you guys taking the t-tops off? Or are you able to wear one with the tops on. And what kinds do you recommend? Thanks for your time
Old Oct 2, 2015 | 09:22 AM
lurch59's Avatar
lurch59
I'm guessing it depends on your height. I can't fit in my 69 with a helmet on unless the t tops are removed, but I am 6'3".
Old Oct 2, 2015 | 10:16 AM
mikem350's Avatar
mikem350
Better find out about the track rules too. I know verts have to run top UP.
Old Oct 2, 2015 | 10:54 AM
gkull's Avatar
gkull
I'm big on safety, So I often exceed the minimums in the rule books. My advice is to buy a 2015 rating because 2010 use might be gone in a year or two. My last helmets have been made the lightest possible, because of neck strain going around a road racing track all day competing or as an instructor. I have a G-force carbon fiber SA2010. They are cheap these days about $250.
If I ever went drag racing again I would have a helmet made with a forced air tube running through a cooler filled with bags of ice. It makes it so nice sitting in the hot staging lanes I drove a 9:40 car last year with the forced cool filtered air and it was sweet even when the interior filled with smoke during the burn out on a 96 degree day
helmets have a Snell Rating the newest being:
SA2015 2015 Helmet Standard For Use in Competitive Automotive
M2015 2015 Helmet Standard For Use in Motorcycling
NHRA RULE BOOK: I was surprised to see 2005 was still good
Be sure to check that snell sticker on your helmet because NHRA rules for 2015 state that "any car running 14.00 and quicker in the 1/4 mile requires a Snell 2005 or newer OR SFI 41.1A helmet (see complete list below)". Also a new NHRA rule in 2008 requires that "any car running 9.99 or quicker in the 1/4 mile requires an NHRA approved FULL face helmet with visor.
Old Oct 2, 2015 | 01:15 PM
FKING1's Avatar
FKING1
Many drag strips require tops to be on.
Zamp is a good Snell helmet & cheapest I have found.
I barely clear with a Corbeau seat & am 5' 7".
Old Oct 2, 2015 | 01:38 PM
C3 Stroker's Avatar
C3 Stroker
I'm 5' 11" and I fit OK in my '69 with my T-tops and helmet on. I guess it depends on how tall your torso is.
Old Oct 2, 2015 | 05:02 PM
jboweriii's Avatar
jboweriii
i'm 5'11", are you using racing seats or stock
Old Oct 2, 2015 | 05:08 PM
BKbroiler's Avatar
BKbroiler
I'm 6'3" with stock seats in my 77. I have to slouch a little to keep my helmet off the t top. At 5'11' you should be OK.
Old Oct 2, 2015 | 09:02 PM
C3 Stroker's Avatar
C3 Stroker
Stock seats.
Old Oct 2, 2015 | 09:46 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
"If you have a $10 head, wear a $10 helmet." Evel Knievel
If that isn't enough to convince you to buy the best SNELL approved helmet you can afford, other [safer] sports beckon.
And, as far as headroom goes, it's your height in the saddle that matters more than how tall you are when standing.
Old Oct 3, 2015 | 08:29 AM
BKbroiler's Avatar
BKbroiler
And, as far as headroom goes, it's your height in the saddle that matters more than how tall you are when standing.[/QUOTE]
There is a correlation between the two and who knows their height in the saddle?
Old Oct 3, 2015 | 09:41 AM
normshark's Avatar
normshark
As said, buy the best/highest rated/newest helmet that you can afford.
Also, don't forget you can take out the t-top liner and gain another inch of head room.
Good luck.
Cheers.
Old Oct 3, 2015 | 11:20 AM
jboweriii's Avatar
jboweriii
I for got about them. thanks
Old Oct 3, 2015 | 03:51 PM
TheSkunkWorks
To better clarify myself, 1) there is no constant leg-to-torso ratio among us humans, and b) perhaps I should have put quotes around the term "saddle" when referring to seated height.
Old Oct 3, 2015 | 04:26 PM
BKbroiler's Avatar
BKbroiler
I didn't misunderstand you. I'm saying that, in my opinion, its safe to assume that of the two different heights mentioned in this thread, 5'11" and 6'3", for males, the 6'3" guy has a greater saddle (seat) height. I realize that the difference in saddle heights between random comparisons of 5'11" vs 6"3" males will vary.
Old Oct 4, 2015 | 06:11 AM
derekderek's Avatar
derekderek
i believe the top off will also add drag. wind drag. even though they call it drag racing, it won't help.
To Helmet for drag racing?
