Coolant Capacity
Old Sep 27, 2015 | 01:53 AM
M A Fry's Avatar
M A Fry
Default Coolant Capacity
G'day All,
Can anyone tell me what the capacity of the coolant system is for an
L46 small block, I have looked hi and low for this info with no luck,
but need to know so I can work out how much antifreeze to add.
Big thanks in advance for any help you can provide.
Mark
Old Sep 27, 2015 | 02:17 AM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Direct from the 1969 manual
Quarts:
350 (Base)
14 (std, no htr)
15 (std, htr)
16.75 (std, auto, no htr)
18 (std, auto, htr)
17 (hvy duty, no htr)
18.5 (hvy duty, htr)
350 (L46)
14 (std, no htr)
15 (std, htr)
427 (non L88)
21 (std, no htr)
22 (std, htr)
21 (std, auto, no htr)
22 (std, auto, htr)
427 (L88)
20 (std, no htr)
21 (std, htr)
21.5 (std, auto, no htr)
22.5 (std, auto, htr)
Hope this helps.
Old Sep 27, 2015 | 07:40 AM
M A Fry's Avatar
M A Fry
G'day Claysmoker,
Outstanding info, thanks very much.
Mark
Old Sep 27, 2015 | 11:17 AM
claysmoker's Avatar
claysmoker
Happy to help.
Old Sep 27, 2015 | 01:49 PM
flyeri's Avatar
flyeri
Just use a 50/50 mix and it will never be an issue if you are starting from completely empty or just adding a bit. Mix you own, 1 gallon at a time, and use distilled water, not tap water.
To Coolant Capacity
