2 core?? 3 core?????
Old Aug 23, 2002 | 11:42 PM
7tea1's Avatar
7tea1
Default 2 core?? 3 core?????
Sorry for the dumb question but, How can I tell how many cores my current rad. has?
I THINK it is the stock radiator for the base 350.
When the cap is off, i notice 4 rows of water tubes, but someone told me that is not how you can tell.
Also, if it is 2 core, can it be recored to 3 or 4 cores, and would I benefit from that?
Thank you for helping!
Old Aug 24, 2002 | 12:19 AM
75Rag's Avatar
75Rag
Default Re: 2 core?? 3 core????? (7tea1)
I'm not really sure but I think a 4 core is the full width of the tanks, a 3 core is 3/4 the width etc. I had mine recored from a three to a four so I would say the answer to part 2 of your question is yes, it can be recored and yes, it should be a benefit (run cooler) provided they are in good shape (your tanks) Hope this helps.
Old Aug 24, 2002 | 12:53 AM
Green76's Avatar
Green76
(7tea1),
Youy have a 4 core radiator if you can see 4 tubes going across as you look down into the radiator.
My original radiator had 3 tubes (3 rows), but I had it replaced with a 4 tube core.
Old Aug 24, 2002 | 11:09 AM
shoptek's Avatar
shoptek
I'd be interested in knowing how to figger it out too :yesnod:
Old Aug 24, 2002 | 01:34 PM
VettePaul's Avatar
VettePaul
Default Re: 2 core?? 3 core????? (Green76)
(7tea1),
I go with that :yesnod: . If you see 4 rows it is a 4 core. Mine was also originally 3 but I've upped it to 4. A friend of mine has just had his '69 rad recored at the same place as mine and he's had a 6 core put in..... :yesnod: six. Personally, with my 4 cores, hi-flow aluminium water pump and flex fan my temp won't go over 150 on the gauge.....VettePaul.
Old Aug 26, 2002 | 07:12 PM
7tea1's Avatar
7tea1
Does anyone know what the stock radiator was for a base 350/270 in 1971???
To 2 core?? 3 core?????
