Power window conversion
Old Sep 30, 2015 | 04:01 AM
327Heaven's Avatar
327Heaven
Default Power window conversion
Hi all,
I asked this question in the C2 section but got no response.
Has anyone added an after market power window kit to their Vette? The vendors kits on this site are quite pricey. Looking for cheaper alternatives that work like the original.
TIA.
Old Sep 30, 2015 | 09:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Why not use the factory installation? The AIMs all show the installation and the parts you will need. You'd get the factory look because it would be a factory installation using factory parts.
Old Sep 30, 2015 | 09:37 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
While I have yet to install it, I picked up the conversion from willcox on sale. It made the price a lot more reasonable.
Old Sep 30, 2015 | 10:03 AM
Richard454's Avatar
Richard454
I used the Spal power windows- nice heavy duty motors with a cable drive- and think they showed up on my doorstep for less than $125- for the pair.
The only trick was getting the correct gear drive- I found the best way was to drill and pin the gear to the OEM crank-so there's no slipping.
Old Oct 1, 2015 | 12:30 PM
sweezey's Avatar
sweezey
Cruising
Default power windows
what is AIMS ??? I have all stock components , harness switches etc...
Old Oct 1, 2015 | 07:37 PM
DUB's Avatar
DUB
Assembly Instruction Manual.
DUB
Old Oct 1, 2015 | 09:34 PM
sweezey's Avatar
sweezey
Cruising
Thanks.!
To Power window conversion
