First of all, thanks to all for answering my questions about cams and heads when I was trying to decide what to do to my '79.
I have decided to do Vortec heads and probably the XE262 cam. One thing I can't seem to find an answer for...Will I be able to use the stock exhaust manifolds with the Vortec heads?
Yes you read that right, "manifolds". Sticking with the manifolds. Don't hate me.
Two things about using Vortec heads, in case you don't know:
Spark plugs are long reach type, not the same as for L48 heads.
Your total ignition timing, initial plus mechanical, with vac advance temporarily plugged, should not exceed 34 degrees.
