454 always over heating problems
Opinions welcome. BB's are cool I guess but you WILL cook/bake or at the very least continually struggle to keep the temp down.
SW
SW
How hot?
As far as interior heat goes, When I got it it was pretty bad but when I replaced the carpet I sealed up all the holes in the firewall and that made a noticeable difference. What made the biggest difference was replacing the hood seal, mine was totally missing and was dumping heat into the ventilation plenum at the base of the windshield and then at my feet. Now its pretty good, not new car good but definitely acceptable. Of course, its a convertible which I'm sure makes a big difference.
SW
thanks,
SW
2. Are you using a wide mouth thermostat? http://www.summitracing.com/parts/mrg-4363
2. What is your initial timing?
3. Is you vacuum advance connected to manifold vacuum.
4. Have you tried an aftermarket water pump such as FlowKooler.
Many thanks for the tip! I'll press or should I say BAKE on...
SW
I put the ball valve out of sight, 1/2 way down to the heater core, then removed the handle & put it in the rear glove box that way I can turn the heat on this time of year her in Ohio
I can take a pic if you like?
Chuck
Fancy high dollar water pumps are a waste of money. The OE pump is the best for a BB
the insulation under the floor and up on the firewall, other year BB don't have that.
as far as engine temp 190-210, Northern IL does not get that hot though.
SW
SW
The stock jute and carpet is insufficient to keep the heat out, as well as the noise. I use Fat mat Mega mat on the floor for noise and refexit on top of that then put the stock jute and carpet back down. Huge difference in interior noise and heat.
Side pipes definitely eliminated a source of heat from the floor pan, just as important was the ceramic coating on the headers which helps to keep the heat in the pipe and going out the exhaust for lower under hood temps.
If I had stock exhaust running out the back I would have heat shields under the floor on the outside to prevent heat from migrating into the cabin.
Also the ball valve on the heater core is a biggie. Two ball valves actually, one on each hose. The heat still gets to the core via conduction if only one is used.
Timing is set at 19* initial. Stock I was at 15* or so. Much less heat in the exhaust pipe this way.
As it stands now I am a little perplexed by the many people that have modded their cars to try to control the heat and have met with little success.
Maybe I have just got lucky but I have had great success thus far. So cold now that when I drive with the wife that she has to cycle the AC off because it gets too cold in the cabin. This is with 134A converted AC no changes in the condenser, hoses, or R4 AC compressor.
SW
