650 enough CCA?
Old Oct 1, 2015 | 12:25 PM
Bloodzone's Avatar
Bloodzone
Default 650 enough CCA?
9.5 compression 383. Starter drags a little. Drags hot and cold. Battery is a Walmart special 650/800 1.5 years old. I know it could be several other things...starter, ground, cables.... Problem started couple months ago and seems to be getting worst. I have a truck that needs a battery so I may get one for the car and kick the old one to the S10 4 cylinder. Looking at one online thats 800/1000. 650 seems low for my engine.
Old Oct 1, 2015 | 12:27 PM
MelWff's Avatar
MelWff
did you have the battery load tested, it doesn't matter the age.
Old Oct 1, 2015 | 12:54 PM
Bloodzone's Avatar
Bloodzone
Never been tested.
Old Oct 1, 2015 | 01:05 PM
Roughrider's Avatar
Roughrider
Have a starter draw test done as well. If the starter is drawing too many amps you have a problem other than the battery...could be as simple as loose or corroded cables or connections or a starter that needs rebuilding.
To 650 enough CCA?
