Wiper Door Issue
Old Oct 2, 2015 | 10:28 PM
Vettesic's Avatar
Vettesic
Default Wiper Door Issue
Having some problems with wiper lid on my 71. Doesn't close completely and at times when car is running it will raise a bit without wipers on. Also wipers don't synchronize together hitting slightly when turned off to park. Obviously a vacuumed problem together with linkage problem? Just looking for prior knowledge from members that have experience with this.
Old Oct 3, 2015 | 08:47 AM
Dave J's Avatar
Dave J
Most wiper door issues stem from the safety valve located under the passenger (right) side wiper arm. If your valve is original, it may be able to be rebuilt. To test, remove the wiper grill, and leave the door installed. If you have a Mityvac or equivalent, disconnect the lower 2 vacuum hoses, connect to the middle vacuum port, and block the lower port. Pump it up, and it should hold vacuum. If no Mityvac, connect a short hose to the middle port, block the lower port, and try to blow through it. You should not be able to.
There are other tests you can do, but this one is the most important one, and it will tell us much about where to possibly go next. Report back.
Old Oct 3, 2015 | 12:55 PM
Alan 71's Avatar
Alan 71
Hi V,
The wiper arms can only fit on the wiper transmission shafts in one way because of the 'keyway' that's part of the shaft and arm base.
Problems with the wipers hitting are often caused either by improper refills or blades being installed or the wiper 'sweep' not being adjusted properly.
There is a screw on each arm that adjusts the angle of the end of the arm/blade. This adjustment often helps with blades that sweep too far or hit at the center.
There is also some 'linkage' adjustment for sequencing the arms at the center of the linkage near the wiper motor.
Maybe?
Regards,
Alan
The 'key' on the transmission shaft.
The 'keyway' in the arm.
Screw 'A' and how it adjusts the end of the arm's angle.
The linkage adjustment at the wiper motor.
Old Oct 3, 2015 | 05:48 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
1968-1972 Corvette Wiper Arm Adjustment
Old Oct 28, 2015 | 01:48 PM
Vettesic's Avatar
Vettesic
Ok. Thanks for all useful info as always on this forum. I've got the wiper door working as it should. Finally snapping shut. Changed vacuum line check valve and filter. Both were leaking. But.....wipers are not parking completely causing door to close on them. Actually only passenger side top wiper getting nipped. I've tried the adjust screw under wiper as pic above shows but still not parking fully.
Old Oct 28, 2015 | 03:06 PM
Alan 71's Avatar
Alan 71
Hi V,
I believe you need to adjust the 2 bolts that position the wiper interlock switch on it's bracket so that the lever that closes the plunger on the switch is further down before the switch signals the door to close.
There should be enough adjustment to do that…. if not you'll need to adjust the wiper transmission arms at the center so the lever pushes the switch when the arms are further down.
Regards,
Alan
Switch adjustment.
Right side wiper transmission arm adjustment.
Old Oct 28, 2015 | 06:22 PM
Vettesic's Avatar
Vettesic
Wiper switch is as low as I can get it without it not functioning or wiper arm not depressing it. I'll give the right arm an adjustment.
Old Oct 28, 2015 | 06:41 PM
Alan 71's Avatar
Alan 71
Hi V,
Are you sure that it's the correct wiper arm, it's not bent, the arm is fully seated on the transmission… did you feel the 'prong 'click'?, and is it the proper blade holder and blade?
Regards,
Alan
Old Oct 28, 2015 | 08:51 PM
Vettesic's Avatar
Vettesic
Unfortunately answers to those questions will require more detective work. Nothing is easy here. What do you mean "prong click"?
Old Oct 28, 2015 | 09:56 PM
Vettesic's Avatar
Vettesic
Alan. Looking and comparing your pics with my linkage and wiper arms all look to be same. Blades look to be correct also. Possibility with bent arm. Let u know when I make further adjustments. Thanks.
Old Oct 28, 2015 | 10:47 PM
BLUE1972's Avatar
BLUE1972
just a thought, double check you're vacuum check valve.. for the pop up issue.
engine under load, low vacuum - up they come if the check valve is bad...
To Wiper Door Issue
