TACH Question
Old Aug 24, 2002 | 12:18 PM
Geoff1340's Avatar
Geoff1340
Default TACH Question
My tach is correct at idle, 800, but seems to be off about 1000 rpm's while driving, indicates 4000 @ 70 mph, engine does not sound like it's turning that...is there a calibration or something I should check?
Old Aug 24, 2002 | 12:26 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: TACH Question (Geoff1340)
Never heard of an adjustment. Have any idea what gears your running?
Tell us more about your car.
Old Aug 24, 2002 | 04:59 PM
Geoff1340's Avatar
Geoff1340
1977, don't have a clue what the gearing is, TH350 trans. L-48, poopie-canned transducer and ran speedo cable direct. Speedo may not be right on but is ballpark...
Old Aug 24, 2002 | 05:00 PM
Geoff1340's Avatar
Geoff1340
Real cute...changes S#!t to "poopie".... :blueangel:
Old Aug 24, 2002 | 06:16 PM
vettinator's Avatar
vettinator
The circuit board for the tach may be your problem. I installed a new circuit board and was supposed to reset it using a voltage somehow. I don't remember how to do it, but you may want to ask about it. Mine is definetly off as I run about 1700 rpm at 70 mph with 3.08s
Old Aug 24, 2002 | 07:47 PM
mrvette's Avatar
mrvette
you probably have a bad tach filter...under the hood....or it's missing...
do a search here for the wiring schematic for it....
bet the tach jumps around also....rev engine in neutral watch it jump irratically....
GENE
Old Aug 26, 2002 | 09:48 AM
Geoff1340's Avatar
Geoff1340
No, Tach dosen't jump around, just seems to read high
Old Aug 26, 2002 | 10:05 AM
Tom73's Avatar
Tom73
Default Re: TACH Question (vettinator)
Are you running an overdrive trans? :confused: Both of my 73's are over 3000 rpm @ 70, one with a 3.08 and the other with 3.36. Your rpm sounds like my 90 with 4speed overdrive auto and 2.73 gears. It turns about 1900 at 75.
tom...
Old Aug 26, 2002 | 12:03 PM
e3pres's Avatar
e3pres
St. Jude Donor '08-'09
My '79 does the same thing. The circuit is good because I'm running a cheapo aftermarket tach for the time being. It's probably the circuit board. I think you can get them for <$100.
Old Aug 26, 2002 | 06:39 PM
Ben Taylor's Avatar
Ben Taylor
If you have a timing light with a tach connector, you could hook that up and see if it reads the same as the tach in your car. If it doesn't then you have a bad tach or circuit board. If it does read the same, then you may have a bad coil or ignition module.
To TACH Question
