Oil Pan Torque Setting..
Aug 26, 2002 | 05:23 PM
What should the oil pan bolt torque be set at?? I heard that if the thin metal stuff like the timing chain cover, oil pan and valve covers are over tightened, then the gasket won't seal. What the correct torque for the oil pan??
Thanks,
Aaron
Aug 26, 2002 | 06:03 PM
Re: Oil Pan Torque Setting.. (Aaron-74)
somewhere in the 10-15 ft-lbs should be good, just make sure they are all torqued down the same amount.
Aug 26, 2002 | 06:04 PM
There are two torque settings. The 1/4-20 bolts are 80 lb in and the 5/16-18 bolts are 165 lb in.
Aug 26, 2002 | 06:17 PM
Re: Oil Pan Torque Setting.. (paul79)
For the oil pan??
My heads weren't even that much... :confused:
[Modified by Aaron-74, 4:17 PM 8/26/2002]
Aug 26, 2002 | 06:22 PM
That is in/lbs not ft/lbs. 120 in/lbs equal 10 ft/lbs
Aug 26, 2002 | 06:26 PM
Re: Oil Pan Torque Setting.. (gmcclurg)
ohhhh...I don't know the in/lbs stuff..
What would 80 and 165 be?
[Modified by Aaron-74, 4:27 PM 8/26/2002]
Aug 26, 2002 | 06:32 PM
Yes, inches not feet. Here are the torque specs for the SB.
Source of reference.
[Modified by paul79, 6:02 PM 8/26/2002]
Aug 26, 2002 | 06:34 PM
What are they in ft/lbs. My wrench only have ft/lbs.
Aug 26, 2002 | 06:53 PM
165 in/lbs divided by 12 = 13.75 ft/lbs.
80 ft/lbs divided by 12 = 6.66 ft/lbs -
My ft/lb torque wrench only goes down to 10 ft/lb, so I would probly use a in/lb torque wrench for these bolts
Aug 26, 2002 | 06:57 PM
Mine goes down to 5 ft/lbs..
