high beam lever
Old Oct 6, 2015 | 03:28 AM
mohd2116's Avatar
mohd2116
Default high beam lever
hi guys ,
i toke my vette to a garage to solve some problems on the dash wiring that i didn't find them on that time, but they are not professional at all , any way when i toke my car from them the beam light lever is not clicking and i found a small metal stick on the floor ,
so my question did any one of you have a guide to let me check and sole that the high beam light is always working and i can't make it low !!
Old Oct 6, 2015 | 07:39 AM
Ontario73's Avatar
Ontario73
Originally Posted by mohd2116
hi guys ,
I think from my deciphering your post that you took your car to a local shop for some work and now the high beams headlights are now on? What year is your car? Most of these old beasts have a foot switch for the high beams that is under the upper left under the drivers carpet.
Old Oct 6, 2015 | 08:21 AM
gbvette62's Avatar
gbvette62
77-82 Corvettes have the high beam switch in the steering column, and controlled by the turn signal lever.
From the OP's post, I'd guess that the nylon portion, of turn signal/high beam switch is broken.
To high beam lever
