stock radio question
You are hearing sound when placing the radio at full volume because the transformer laminations in the loading coils inside the radio are vibrating.
To confirm this place any type of speaker across one pair of the green and black speaker leads. If the sound returns, call Greg Thompson at 18777802861 for a correct set of aftermarket replacement speakers made for that radio. They work very well!
Use correct speakers as the internal Delco audio amplifier modules are unique in 76's and rare. You don't want to strain them to failure! No, I'm not referring to the dual DS-501 transistors on the convector for anyone thinking that.
The good news is that your radio is probably still working correctly.
Click on the pdf at this link and it'll walk you through how to get the pad out. You need to remove the right visor, right pillar post, right lower dash pad and then the center dash bezel. Once you get to this point, remove the upper. When you go back you might wish to add some length to the lh speaker harness, it makes the re-install a little easier.
Willcox
1968-1977-corvette-dash-pad-remove-and-install-instructions
Willcox
A very nice and thorough and helpful collection of information on your site. Thanks for sharing the bliss and well done!
You also could have a failed pre-amp section in the radio head or a problem with the 'convector' (the aluminum heat sink with either 1 (mono) or 2 (stereo) transistors on it that lives behind the right-side dash pad). The convector is the final stage of amplification; if it is not boosting the pre-amp signal, the sound will be very weak.
There are folks who actually repair these things and that's who you would need to get the radio to so that it could be diagnosed and have problem component[s] replaced.
Jerry_the_Radio_guy is one of those folks and he is on this Forum occasionally. I don't have his contact info, but you can do a search on his 'tag' and find it from there. Others may chime in with that info or similar info on other good Delco radio repair folks.
I was one of those guys! I changed both speakers just like Jerry said and it corrected the problem.
George
Test it first. If I'm wrong, you won't have strained yourself pulling the dash.
Here's the easy way to test: unplug both speakers. Take a 1.5 volt DC battery (which is the voltage from the radio that is normally measurable on each speaker anyway for a stereo) and touch the batteries + and - ends to the green and black leads of one of the speakers. You should hear a thump sound if the speaker is good. Do the same with the other speaker. Polarity of the battery is not important.
No thump, no good.
The black liquid tape sealant over the voice coil to flexible terminal wires on the front of the speaker hardens up. Then the volume gets turned up and the extremely thin coil wires shear off. Dead speaker.
Other times the carbon wire under that black goop breaks down due to moisture and turns to green powder. No wire left. Dead speaker. :-)
Rejoining the real world for a little while so will check back to see if you had luck when we get back.
PS: HI George! I remember.
in the kick panel was that originally for speakers also
Both Wilcox and Hoyle will remind you that it's a Corvette and therefore always "a little more involved".
If I'm following your question correctly then yes, 68 and 69's have 4X10" speakers in the kick panels, none in the dash.
They improved the mid-range and bass marginally over the 4X6"'s in your dash. The setup in my pace car had stock 6X9's in the rear and that combination of 4X6 and 6X9 was pretty good. The larger speakers move a lot more air at the lower frequencies. And they were closer to ear level like you have.
Delco kick panel speakers are OK if your ears are at ankle level. GRIN Good bass speakers in the panels help because higher frequencies are more directional and low frequencies will saturate. There are only so many watts available in those old radios and how you distribute them is important.
Hope that is useful and in line with your question. Decades ago I designed speakers for use by the deaf and had access to ElectroVoice engineers and test equipment (and an anechic chamber). The moral was keep it simple and efficient in the environment (and affordable).
And yes, your radio and any of the 68-72 stereos can drive a total of four speakers as long as the DC bias on the speaker lines is re-adjusted downward about 0.25 volts!
so after I get it fixed what speakers should I put in the kick panels so my feet can hear better
