80 power antena
Old Oct 15, 2015 | 02:38 PM
Grumpy 427's Avatar
Grumpy 427
They are a "Motive Gear" part D44-354. I got them from JB power in Edmonton Alberta. $160.00 Canadian for the gear set.
Old Oct 15, 2015 | 02:39 PM
Grumpy 427's Avatar
Grumpy 427
Thanks Guys i am n electronics tech/ electrician by trade, i am very aware of good grounding. My buddy lost a camaro in a fire due to poor grounding.
Old Oct 15, 2015 | 06:48 PM
hugie82's Avatar
hugie82
This popped into my head but if you ever took apart a pull starter on a lawn mower or an small engine, it's very similar to that. You have to anchor the nylon rod in a notch. Then wind it up, hold it all together and screw the plate over it.
Old Oct 15, 2015 | 07:00 PM
Grumpy 427's Avatar
Grumpy 427
Ok cool thanks for the tip.
Old Oct 15, 2015 | 09:46 PM
Lakeside49's Avatar
Lakeside49
Good analogy! But, much easier than installing the pull-starter example because there is no return spring tension.
Have tube of fresh grease. The old stuff gets dry and crusty being subject to muffler heat (I painted mine silver to help reflect the heat a bit. It cannot be seen as it is well tucked up there.
