50-75 more horsepower
Old Aug 25, 2002 | 01:36 PM
davds96's Avatar
davds96
Default 50-75 more horsepower
I have a 78 L48 4-spd runs real strong but would like 50-75 more horses
What would be your advise to acheive this with the original engine I am planning a rebuild after the first of the year and want to get everything ready first
also please advise cost of up grades
thanks as always on your input
Old Aug 25, 2002 | 01:46 PM
Taijutsu's Avatar
Taijutsu
Default Re: 50-75 more horsepower (davds96)
No rocket science needed here! There are so many SB build ups that you can shop for the power you need. A good rebuild that includes new heads cam and intake will give you 50-75 hp. Now you have to ask yourself how many rpms do I want to go? The Vortec heads are about 400, cam and lifters are 200 and 150 for intake. Add in dual exhaust andf you are there. You can spend less or more depending on your goals.
Old Aug 25, 2002 | 01:51 PM
QuickVet's Avatar
QuickVet
Default Re: 50-75 more horsepower (Taijutsu)
The vortec setup should do it . that is definatly the most cost effective way to do it :yesnod:
Old Aug 25, 2002 | 02:30 PM
devveldogg's Avatar
devveldogg
I'm partial to a little shot of NOS :yesnod: :seeya
Old Aug 25, 2002 | 02:52 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Get World Products Sportsman II Heads - that's at least 50+++ HP...
I have seen them for approx. $700
:cheers:
Olivier
Old Aug 25, 2002 | 03:39 PM
Shark Racer's Avatar
Shark Racer
The setup in my sig should put me at ~170 hp over stock. :)
Now, I need to start a PacinCA engine charity fund.
-Steve
Old Aug 25, 2002 | 04:39 PM
nunus79's Avatar
nunus79
Sportsman IIs netted me 55 hp while even using stock exhaust 2-1-2 system sans operational catastrophic converter. Mountainmotor has been messing around with Protopline heads that look even more promising. Should check it out, approx $750.
Old Aug 25, 2002 | 05:14 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: 50-75 more horsepower (nunus79)
what do you guys think of these heads ??
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1853782186
Old Aug 25, 2002 | 05:33 PM
QuickVet's Avatar
QuickVet
Default Re: 50-75 more horsepower (Metal_Wulf)
look good to me :cheers:
To 50-75 more horsepower
