Mounting bracket to front fender
Old Oct 18, 2015 | 09:36 AM
Robban f's Avatar
Robban f
Default Mounting bracket to front fender
Is there someone who can help med find the brackets to the front fender.
There is one on each side bolted together with the frame.
Both mine are missing!
It works without but probably god to have in a colision.
Corvette c3 1972.
Regards Robban from sweden
Old Oct 18, 2015 | 10:23 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Are you looking for #7 or #10.
#10 https://willcoxcorvette.com/catalogs...er+bumper+brac
#7 https://willcoxcorvette.com/catalogs...rossmember+ext
Old Oct 18, 2015 | 10:56 AM
Alan 71's Avatar
Alan 71
Hi R,
Here are a couple of pictures that show the area in the drawing that W posted.
#7 is the frame extension that carries the forward crossmember and #10 is the corner bumper bracket.
You're right in thinking they're good to have in place just to mount the bumper properly…. hopefully they'll never be needed in a crash.
Regards,
Alan
Old Oct 18, 2015 | 12:32 PM
Robban f's Avatar
Robban f
Hi yes its number 10 i'm after,
But it seems overkill with the 10 bracket, the fender have multiple fastening points, but of course it should be there
Aldo I need everything in front of bracket number 10.
Also what kind of fasteners you use for mounting them, looks like small rivets( do you call them that?)
Regards robban
Old Oct 18, 2015 | 12:41 PM
c3_dk's Avatar
c3_dk
Originally Posted by Alan 71
Hi R,
Regards,
Alan
Alan, it this in your living room? :- )
It must be, I wonder what your wife says to you :- ))
I love to see your pictures Alan, you have done a perfect job with that 71
Old Oct 18, 2015 | 12:48 PM
Robban f's Avatar
Robban f
I was wondering the same, beautiful car Alan
Old Oct 18, 2015 | 12:56 PM
0Willcox Corvette
Former Vendor
Regards robban
You'll need the extension part listed at the same link for number 10... https://willcoxcorvette.com/corvette...-bracket-70-72
Bumper bolt kit will have the bolts you need to mount them.
https://willcoxcorvette.com/corvette...headmark-68-72
Willcox
Old Oct 18, 2015 | 12:59 PM
Robban f's Avatar
Robban f
Isn't the fender bolted to the body on various locations?.
It seems the main construction for the extension bracket is to support the hole front body aswell?
Old Oct 18, 2015 | 01:01 PM
Robban f's Avatar
Robban f
Willcox
Ok thanks.
I was thinking about the sealings around in the pictures, i forgot to write that in the previous thread
Alan 71's Avatar
Alan 71
Hi R,
There are 2 small brackets forward of #10.
I'm not sure what rivets you're referring to? Perhaps those that hold the reinforcement to the front edge of the hood surround?
Regards,
Alan
Old Oct 18, 2015 | 01:03 PM
Alan 71's Avatar
Alan 71
Hi c3 dk,
My restoration days are over so I can have a laminate floor in my basement garage.
I need to be careful with it though!
Regards,
Alan
Old Oct 18, 2015 | 01:07 PM
Robban f's Avatar
Robban f
Hi R,
Regards,
Alan
I'm sorry i meant for the sealings around
Old Oct 18, 2015 | 01:08 PM
0Willcox Corvette
Former Vendor
Inner fender bumper brace seals. https://willcoxcorvette.com/corvette...ce-seals-68-72
Old Oct 18, 2015 | 01:15 PM
Robban f's Avatar
Robban f
I have them new in bag but what do you mount them with?
Old Oct 18, 2015 | 01:18 PM
c3_dk's Avatar
c3_dk
Hi c3 dk,
Regards,
Alan
Then you have to get a new project Alan, we need to see your pictures :- )
It is a ones in a lift time, to see a new 71 in 2015 :- )
And sometimes, do you just (ones) want to make a VERY small bubba ? :- ))
Regards,
John
Old Oct 18, 2015 | 01:20 PM
Alan 71's Avatar
Alan 71
Hi R,
The seals were attached using staples.
You should still see the holes from the originals in the fiberglass apron.
Look at the last pic in post #3.
Regards,
Alan
Old Oct 18, 2015 | 01:23 PM
Alan 71's Avatar
Alan 71
Hi John,
While I try not to be bubba, I can really screw things up trying to do things I don't know how to do!
Luckily I don't mind re-doing things over, and over, and over!
Regards,
Alan
To Mounting bracket to front fender
Old Oct 18, 2015 | 01:28 PM
c3_dk's Avatar
c3_dk
Hi John,
Regards,
Alan
Ok, now I know you are human like the rest of us :- ))
I still think you should buy a new project OR come to Denmark, and help me with my 69 project :- )
Old Oct 18, 2015 | 02:40 PM
Alan 71's Avatar
Alan 71
Hi John,
Coming to Denmark sounds interesting but it would probably have to be during the summer because I don't do well in FRIDGID weather.
Regards,
Alan
Old Oct 18, 2015 | 03:21 PM
Robban f's Avatar
Robban f
Hi R,
Regards,
Alan
I compared the small brackets at the end of bracket number 10 willcox showed and those on your car, doesn't look the same, how they are bent.
