New alternator - difference in cast
Old Oct 20, 2015 | 03:01 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default New alternator - difference in cast
My alternator died on me last Saturday (actually, it died on Friday night and luckily, my battery held up for a 60 mile trip with the headlights on without a functioning alternator.. So, on Sunday, I got a remanufactored alternator from Advance Auto Parts and Installed it.. When I installed it, it would not fit into the header alternator bracket ( F shaped bracket) correctly.. (it would not lean towards the engine far enough to attach the belt.. Upon closer inspection, I noticed that there was a slight difference in the cast between the new and old alternator. A non-functional lip was in the cast of the new alternator (no idea on why this was there). As I didn't want to bring it back and look for another alternator, I used a grinder and ground down that lip and after doing so, it fit perfectly into the bracket.. Has anyone else noticed such different in cast on a replacement alternator?
Old Oct 20, 2015 | 03:25 PM
toobroketoretire's Avatar
toobroketoretire
Likely made in China and not an exact duplicate......................
Old Oct 21, 2015 | 08:32 AM
GrandSportC3
Not made in china but remanufactured in Mexico (just like all the standard GM 350 crate engines are made at).. It's GM parts but it seems that the case has one minor difference which is that little lip..
Here is a pic of how exactly the piece of the cast looked like that interfered with my alternator bracket.. (circled in red).
However, in this picture, that cast is in a different spot where it would NOT interfere.. There seems to be no functional reason for that..
Old Oct 21, 2015 | 08:48 AM
JimLentz's Avatar
JimLentz
Could you have rotated the back half of the alternator case to make it work?
Old Oct 21, 2015 | 09:55 AM
GrandSportC3
I don't recall on which part of the cast the issue was. It might have been possible to rotated it and solve the problem that way but I ended up grinding down that part of the cast as it had no functionality anyways (at least in a '68 Vette).
I didn't think of rotating one section of the alternator.. I had many C3's and tons of alternators but never ran into a issue like that before..
Old Oct 23, 2015 | 05:49 PM
mrvette's Avatar
mrvette
I have run into this over the decades man, don't remember which car but WANT to say this '72, and yes the clocking of the FRONT section is the difference, the iron field windings clock only one way to the REAR section, not the front aluminum piece, THAT you can flip around any way you want.....BUT you have to do the commutator brush trick with a piece of paper clip/wire to hold the brushes away from the slip rings while inserting the front plate/armature into position, see that it agrees with your car, THEN pull the paperclip/wire out to hear that both of the brushes make a nice click upon removal....
Old Oct 23, 2015 | 07:42 PM
toobroketoretire
It is standard procedure to "clock" an alternator so the position of the wires is the same as your original alternator. The C3's need to have their side plugin pointing directly to the left side so the low hood won't hit the plugin.
Old Oct 23, 2015 | 08:31 PM
Sayfoo's Avatar
Sayfoo
I've found this to be true to get the electrical plug in the correct position. The alt. may work as purchased, but clocking is more correct.
Old Oct 23, 2015 | 09:36 PM
GrandSportC3
Well, it's too late now anyways..but good to know.
To New alternator - difference in cast
