1980 Electrical Question
Old Oct 25, 2015 | 06:36 PM
koshe2's Avatar
koshe2
Default 1980 Electrical Question
Got an 80 vette that has been off the road since 96. Fresh gas and oil runs amazing. The question I have is I have a lot of things that don't work. Dash lights, headlights, tail light, brake lights, blinkers, flasher.
Radio and PW work. Battery light stays in with car off. Is there some common link that I need to check?? Ground???
Any ideas would be great.
Old Oct 25, 2015 | 06:47 PM
havesometo's Avatar
havesometo
Check the fuses on driver side of car under dash.
Old Oct 25, 2015 | 06:48 PM
BlackC3vette's Avatar
BlackC3vette
Check to see if your getting battery voltage to the power and line side of the fuses for those circuits. It could just be surface corrosion on the fuses.
Old Oct 25, 2015 | 07:05 PM
koshe2's Avatar
koshe2
OK Fuses look OK. Does anyone have a diagram of that panel? I cant read it.
Old Oct 25, 2015 | 07:29 PM
TX-Techman's Avatar
TX-Techman
I would suggest getting a wiring diagram for your car and a voltmeter then start testing. Below is a link from Google on the fuse block, hopefully this will give you a starting place. I purchased an enlarged laminated color wiring and vacuum diagram for my 69 which is invaluable for this type issue. The things you have listed are directly powered from the battery and do not go through a relay or ignition system. Since the car runs and radio ad power windows work is seems the ignition switch and peripherals are functional. Your issue is something on the primary feed from the battery probably prior to the fuse block or a grounding problem.
Fuse Block Photo
https://www.google.com/search?q=1980...GKVQNjIP3-M%3A
Old Oct 25, 2015 | 08:33 PM
havesometo's Avatar
havesometo
Old Oct 27, 2015 | 07:23 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
You can also have a look at your light switch , I have seen some with the backs melted and the wires burnt off.
Old Oct 28, 2015 | 07:28 AM
dea999's Avatar
dea999
1st Gear
Had a similar problem on my 76, problem was in the turn signal switch. it was shorting everything out from corrosion
To 1980 Electrical Question
