My 357 build
Old Oct 31, 2015 | 08:45 AM
Heus's Avatar
Heus
Default My 357 build
I am using an ATK short block as a base for my 357 build to drop in my 78 with new Dougs Side exhaust Here are the specs so far:
80-85 4 bolt main block bored .040 over
Hyper flat top 4 v relief pistons
Stock reground and balanced nodular iron crankshaft
Powdered metal rods
Howards Retro roller cam and lifters .525/.525 110 LSA
Lunati double roller timing chain w/ torrington bearing
Cloyes 9-221 quick button aluminum timing chain cover
Melling HV55 oil pump with bolted on pickup
Looking at 64cc 185 2.02/1.60 heads for approx. 9.9/1 compression. Looking at Promaxx, Blueprint, ATK/ profiler heads
Dual plane intake
Probably an Edelbrock carb not sure of 600 or 750 cfm
Old Oct 31, 2015 | 09:48 AM
diehrd's Avatar
diehrd
Spend a tad more money and get a forged crank , Also why not use a one piece rear main block ? Then you have a better block made for a roller cam.
Old Oct 31, 2015 | 02:02 PM
Heus's Avatar
Heus
Yeah except I already have the short block.
Old Oct 31, 2015 | 02:42 PM
uxojerry's Avatar
uxojerry
What's your budget on heads?
Old Oct 31, 2015 | 03:38 PM
Heus's Avatar
Heus
Old Oct 31, 2015 | 04:10 PM
uxojerry's Avatar
uxojerry
Check with Weingartner Racing. He can help you out. His ported Dart 180s would be a nice fit.
Old Oct 31, 2015 | 05:31 PM
Silvertone's Avatar
Silvertone
I got an ATK 385 crate motor a couple years ago and they used Profiler 195cc heads. Dyno'd at 486hp and achieved my goal for the street: 500lbs of torque from 3600 to 5200rpm. Not bad! I did a lot of research on aluminum head flow numbers and these heads certainly keep pace with the much more expensive heads. (They know who they are.) Profiler has earned my endorsement.
Old Oct 31, 2015 | 06:45 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Old Oct 31, 2015 | 07:12 PM
HP Hunter's Avatar
HP Hunter
Toss the HV pump, to many issues longterm. Use the M55A
Harry
Old Oct 31, 2015 | 09:30 PM
96 lt-4's Avatar
96 lt-4
I would run larger than 600cfm for a carb and it wouldn't be an edelbrock unless it was the AVS.Buy what you are comfortable with just be ready to tune on it some.
Old Nov 1, 2015 | 01:09 AM
c3_dk's Avatar
c3_dk
Originally Posted by Heus
800-1200
There is also very nice new iron heads, that will give you the same performance as aluminium heads.
Old Nov 1, 2015 | 07:56 AM
Heus's Avatar
Heus
Which ones?
Old Nov 1, 2015 | 09:44 AM
c3_dk's Avatar
c3_dk
Which ones?
http://www.ebay.com/itm/SBC-CHEVY-DA...xU3YFM&vxp=mtr
Or bit more and go for AFR
To My 357 build
