1980 1 owner
Comments are welcome.
Terry Baumsten
1st digit - Make
1=Chevrolet
2nd digit - Model
Z=Corvette
3rd & 4th digits - Body Style
87=Two door coupe
5th digit - Engine
8=350ci 190hp, 6=350ci 230hp, H=305ci, 180hp (California)
6th digit - Year
A=80
7th digit - Assembly Plant
S=St. Louis
The last numbers are the unit numbers starting with 400001, so that is #7,320 out of 40,614.
Its definately a turbo 350.
You can go to http://www.ncrs.com and use the calculator to get the birthday.
Please post the info from your trim tag(driverside between dash and door), I am curious.
[Modified by 71,454,4spd, 12:48 PM 8/26/2002]
130,000 miles and 8 years of storage can spell lots of work.........Be prepared for bad/rotted out suspension rubber parts, replacement of all hoses and belts, leaking radiator and heater core. Rusted brake caliper cylinders, unless replaced along the line with Stainless Steel lined calipers.
Would not personally spend any serious money on the 305, just pull it, and replace with a GM Crate 350 or better, if you want more performance, not necessarily recommended if your teenager will be driving the vette, but then you know him better than me.
Transmission seals may be dried out and leak, but with 130,000, you're close to time to do a rebuild anyway. I'd be surprised if exhaust system wasn't rusted out, and rememeber that you've got to pass smog test in Cali........so I'd make sure all smog stuff for engine is still there........(Don't think smog cops can tell that you've replaced the 305 with a 350)
Check interior out really well, as this can be replaced, but can get expensive.
You can always get it on the road first for as little bucks as possible, then start into the cosmetics (paint, weatherstripping, etc...).
Believe AIM is abbreviation for Assembly Instruction Manual, which is a photo copy of the actual three ring binder manual used by GM employees in the assembly of that particular year corvette.........different manual for each year, manual even has some 'margin' notes, and can be purchased from many corvette suppliers.
Based upon your additional description, I'd say go for it, pick up the vette, and start by changing all fluids, filters, hoses and belts, bleed the brakes, install a new battery, remove spark plugs and squirt oil into each cylinder, install new spark plugs, remove gas tank and drain all old gasoline, unless done before being placed into storage, add new gas, and fire that bad boy up!!!!!!!!!!!!!!
