Missing parking brake cable frame brackets
Old Nov 7, 2015 | 04:42 PM
DENNY63's Avatar
DENNY63
4th Gear
Default Missing parking brake cable frame brackets
My 73 is missing the frame parking brake cable brackets. I think they rusted away? Anyway I need to get some bolt on or weld on replacements. Where was the original location? Pictures would be a great help. Thanks. Den
Old Nov 7, 2015 | 05:18 PM
Mooser's Avatar
Mooser
Those are pretty solid to "rust away"
Driver side
Or are you looking somewhere else?
M
Old Nov 7, 2015 | 06:10 PM
DENNY63's Avatar
DENNY63
4th Gear
Default Brackets
Yeah, I thought they might be a little thick to rust away. But there is nothing hanging off the frame rail? Not sure way anyone would remove those? I'd take a picture but it too dark now.
Old Nov 7, 2015 | 06:19 PM
Mooser's Avatar
Mooser
The parking brake system has never been known to be spectacular so maybe someone just threw in the towel and removed it all?
Anyway, that's where they should be, pass side is the same. Two threaded holes into the frame for each bracket. Pretty much right under the cross brace
HIH
M
Old Nov 7, 2015 | 06:49 PM
DENNY63's Avatar
DENNY63
4th Gear
Default Brackets
I'll look for the holes tomorrow. Thanks for the photos, I just put new stainless hardware and shoes and cables are next. Den
Old Nov 7, 2015 | 11:22 PM
USA-OSC's Avatar
USA-OSC
My "73 PO removed the brackets on the TA's because they interfered with the wheels he chose to run. I have since had them replaced and now running stock wheels. He was not running an emergency brake but I now have one.
Old Nov 8, 2015 | 06:31 AM
DENNY63's Avatar
DENNY63
4th Gear
The plot thickens, that may be? I have American Racing wheels. I'll check the clearance. She had all the stock steel hardware all rusted up no cables. I'd like to switch back to the factory rims anyway, much better looking.
To Missing parking brake cable frame brackets
