toe in
Old Nov 7, 2015 | 12:43 PM
Capt Ken's Avatar
Capt Ken
Default toe in
The last time I had the car aligned, the tech said he did not put in the specified toe in becauese it is not needed with radial tires. I'm running 255/60 R 15s. How much toe in should I have?
Old Nov 7, 2015 | 12:48 PM
Bronze85's Avatar
Bronze85
What year car is it, did it come with radials? Toe in/out is an adjustment needed to prevent premature tire wear.
Old Nov 7, 2015 | 01:09 PM
zwede's Avatar
zwede
Front or rear? In the front you can reduce toe-in to close to zero with no problems. It becomes more eager to take a turn. Reduce it too much and it will wander on the highway.
Rear needs quite a bit of toe-in due to the suspension design. It toes out in compression, so you need static toe-in to compensate (you never want toe-out in the rear, car becomes unstable).
Old Nov 7, 2015 | 02:49 PM
toobroketoretire's Avatar
toobroketoretire
The last time I had the car aligned, the tech said he did not put in the specified toe in because it is not needed with radial tires. I'm running 255/60 R 15s. How much toe in should I have?
I run about 1/8" but I have read up to 1/4" is okay.
Old Nov 7, 2015 | 02:54 PM
Capt Ken's Avatar
Capt Ken
Default re
It is a 73, don't think they came with radials originally. Front toe in. Thanks for the replys
Old Nov 7, 2015 | 08:04 PM
sandy laker's Avatar
sandy laker
http://www.vbandp.com/index.php?opti...=43&Itemid=131
Download the .pdf file at the top of the page for radial tire alignment specs from Vette Brakes Co.
Old Nov 8, 2015 | 12:50 AM
7T1vette's Avatar
7T1vette
About 1/8" +/- 1/32"
You NEED some toe-in to keep the front end from wandering around (instead of driving 'true').
Any relatively light car with wide tires needs a bit of toe-in. And, only the front tires need it.
Old Nov 8, 2015 | 07:53 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...It is a 73, don't think they came with radials originally....
Radial tires became standard equipment beginning with the 73s.
Old Nov 8, 2015 | 08:37 AM
cottoneg's Avatar
cottoneg
Check this post:
https://www.corvetteforum.com/forums...ent-specs.html
To toe in
