Window trouble
Old Nov 9, 2015 | 01:12 PM
vannmike's Avatar
vannmike
Default Window trouble
My windows (both sides) in my 77 only roll half way up. They go and the just stop. I can roll them back down, just not all the way up. And both window actuators are new. Any advice?
Old Nov 9, 2015 | 06:32 PM
vannmike's Avatar
vannmike
Need some help guys? Anyone?
Old Nov 9, 2015 | 08:43 PM
mrvette's Avatar
mrvette
When you replace those actuators, I ASSume you looked at them and saw a coil spring that looks like a electric stove calrod....flat and with a lip on the inside that graps a slot on a ~1/2 inch shaft, the outer edge has a tab that catches a support....
the spring helps bring the windows up.....without it, the motor is typically only 1/2 way up......
These springs are black and faced to the outside of the door.....
they tend to rust/break on the inside tab over the shaft....
damnit.....
Old Nov 10, 2015 | 12:44 AM
TOM B1's Avatar
TOM B1
Or the motor lost there power
Old Nov 10, 2015 | 12:02 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You said the actuators are new, I'll assume you mean the regulators? But what about the motor drive gears, what condition are they in? Seems odd both would do the same thing.
Other possible issues:
Power window motor.
Linkage jamming.
Roller issue
Old Nov 10, 2015 | 01:19 PM
The Money Pit's Avatar
The Money Pit
I just replaced mine and the new regulators had a bolt you are supposed to remove after you install the motor. Just a thought.
Old Nov 10, 2015 | 02:21 PM
vannmike's Avatar
vannmike
Would they only half way work though?
Old Nov 10, 2015 | 02:22 PM
vannmike's Avatar
vannmike
There getting power, so could they lose SOME of the power
Old Nov 10, 2015 | 02:23 PM
vannmike's Avatar
vannmike
Power window motor.
Linkage jamming.
Roller issue
I'm sorry, the motors are new. And your right, they are both doing the samething
Old Jan 19, 2016 | 03:59 PM
Richard Daugird's Avatar
Richard Daugird
Did you ever figure this out?
Old Jan 20, 2016 | 09:55 PM
vannmike's Avatar
vannmike
Tranny went out so been on that, also doing control arm bushings. But I did grease the **** out of the driver side tracks and it goes up alot better. Just not perfect
Old Jan 26, 2016 | 02:14 PM
Richard Daugird
Mine stops an inch short going up, drivers side. I will check that spring.
To Window trouble
