A Good Tip About Replacing Valve Cover Gaskets
Old Nov 10, 2015 | 02:32 PM
toobroketoretire's Avatar
toobroketoretire
Default A Good Tip About Replacing Valve Cover Gaskets
A long time ago I learned a valuable tip about replacing valve cover gaskets. Rather than using a weatherstripping cement like 3M-8001 or 3M-8008 use an oil resistant RTV to glue the gasket to the valve cover then let the RTV completely cure before installation. When valve cover gaskets leak they leak between the gasket and the valve cover; not between the gasket and the head as most people think.
Take a good look at a gasket that is stuck to a valve cover. With the valve cover tilted to a 45 degree angle (like on a Chevrolet V8) you'll notice the gasket forms a "ledge" on the bottom that oil will collect on then leak out between the gasket and the valve cover. When the valve cover gets installed the gasket will squash OVER the head rail and that "over" allows oil to drip off rather than leaking out between the gasket and the head.
Old Nov 10, 2015 | 07:42 PM
76Rat's Avatar
76Rat
WTF are you talking about. Do you just make this crap up?
Old Nov 10, 2015 | 10:39 PM
JENNIFERc6's Avatar
JENNIFERc6
Agreed - Where does weatherstripping cement let alone RTV ever get called for in the Assembly manual let alone used at anytime for valve covers :S
Old Nov 11, 2015 | 12:24 AM
keithinspace's Avatar
keithinspace
My valve covers come off at least twice a year. It'd be a real mess if I used any sort of RTV or sealant.
I just use the nice rubber gaskets. No leaks, either.
Huh.
Old Nov 11, 2015 | 12:54 AM
Big2Bird's Avatar
Big2Bird
too broke was an engineer. We just don't know which railroad yet.
Old Nov 11, 2015 | 01:48 AM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Old Nov 11, 2015 | 08:37 AM
edk136's Avatar
edk136
Welp... there goes my coffee all over the computer monitor
Old Nov 11, 2015 | 09:10 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Lionel!
Old Nov 11, 2015 | 10:32 AM
Ironcross's Avatar
Ironcross
Default 3 m
One of the best ways to replace valve cover gaskets is to use 3-M.....the silicone is actually a gasket by itself....Want double gaskets?..Only bench racers would use both a gasket and silicone...making a bad problem only worse....I don't care what brand of gasket used but the 3-m products hold solid into the valve covers and you not be plagued by hitting rockers and dislodging the gasket from the cover......which really causes the leaks.....Put some bearing grease on the head side and you can use the gaskets over and over.....
My engines are opened up after nearly every pass and replacing valve cover gaskets is not one that's ever replaced......
Last edited by Ironcross; Nov 11, 2015 at 10:44 AM. Reason: [URL=http://s238.photobucket.com/user/waltspuffer/media/My%20Drag%20cars/O
Old Nov 11, 2015 | 11:33 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Whenever I've had to open up a valve cover, and consequently replace the gasket, I've used a LIGHT coat of RTV to secure the RUBBER replacement gasket to the valve cover, and then as "Ironcross" mentioned, skin the gasket with a little grease, and DON'T OVERTIGHTEN. That will last you pretty much a lifetime....
Old Nov 11, 2015 | 12:54 PM
havesometo's Avatar
havesometo
To A Good Tip About Replacing Valve Cover Gaskets
