Help with correct part number
Old Nov 11, 2015 | 09:20 AM
HunterPayne's Avatar
HunterPayne
Default Help with correct part number
I have a 71 base model- 350 4speed. I have been trying to track down the correct clip for the vacuum line right behind the master cylinder. Does anyone know the part number? I have been searching and just can't find it.
Thank you.Name:  IMG_1681.JPG
Old Nov 11, 2015 | 09:31 AM
Alan 71's Avatar
Alan 71
Hi HP,
It appears 2 different clips seem to have been used sporadically at that location.
I'll try to find the numbers.
The first I see in reproduction (try Corvette Central, HDL-319), the second only as used originals.
Regards,
Alan
This one, it's the same as those used on the left side apron for the vacuum hose bundle and harness:
And this one:
Old Nov 11, 2015 | 09:33 AM
jotto's Avatar
jotto
Not sure but could it be GM 3977708?
Is it the clip that holds all the hoses together? If so, I believe the 71 needs 5.
HunterPayne
thank you. I have the one in the top picture but it does not seem right because I don't have the brake booster and it hangs over the master cylinder cover..
Old Nov 11, 2015 | 09:34 AM
jotto's Avatar
jotto
Alan and his beautiful pictures to the rescue!
Old Nov 11, 2015 | 09:40 AM
HunterPayne
Absolutely!!!! I just had all the guys at work admiring just the one corner of the engine compartment.
Old Nov 11, 2015 | 10:11 AM
Alan 71's Avatar
Alan 71
Hi HP,
I have seen the longer type of clip on cars without p/b and you're right the clip does extend over the mst/cyl lid.
The pic of the car with p/b is actually an LS6 restored by someone who's a member of this Forum and also a pretty special Corvette guy!
Regards,
Alan
To Help with correct part number
