electrical draw
Old Nov 16, 2015 | 08:12 AM
blue by you's Avatar
blue by you
Default electrical draw
I have a electrical draw, I have pulled the fuses and found it in the interior lights. Now I not the best when it comes to this and I know there is a lot on this circuit so any help to how to trace the problem would be a big help. It's a 71 sb 4sp coupe
Old Nov 16, 2015 | 09:46 AM
SwampeastMike's Avatar
SwampeastMike
What year?
Also the interior lights are on the CTSY (courtesy) circuit along with many other things. In general anything that requires constant power (ignition in "OFF" position) was and is put on that circuit. Even from the factory the CTSY circuit is pretty much a splice-filled mess that snakes throughout the entire cabin.
Old Nov 16, 2015 | 09:52 AM
Bills17n72's Avatar
Bills17n72
maybe the glovebox light stays on ,or I think the burglar alarm is also on the same line ,if it is the alarm ,I think you can disconnect it between the seats in the console.
Old Nov 16, 2015 | 10:29 AM
blue by you
the glove box light is disconnected and the car is all original the wiring is not cut up and it's like it happened overnight
Old Nov 16, 2015 | 10:56 AM
SwampeastMike
Again, year does matter.
If you have a power antenna it is most likely in that circuit. If the nylon cord inside a factory style antenna is about to break (i.e. stretching slightly) it will not "kick" the down limit switch. The motor will stall and cycle on thermal overload. A defective limit switch in any power antenna antenna (either down or up) would do the same thing if stuck closed.
Do you have the courtesy light turn-off delay? If so the module is a well-known cause of excessive draw. Again year matters as I only know about 78+ which have a real glove box. In them you remove the glove box interior and find the delay module taped (it should be) to the wiring harness to the right and slightly above the glove box.
Old Nov 16, 2015 | 02:33 PM
blue by you
it is a 71 no power ant no delay lights
Old Nov 17, 2015 | 12:08 PM
F22's Avatar
F22
Do you have a multimeter? Because you could measure the current, even with the car off. Because you have a draw, that means that the circuit is using electricity and if it's using electricity, there is an electrical current running through it (and it could be any circuit, not just the one you're looking at).
Old Nov 17, 2015 | 12:21 PM
blue by you
yes I do have a meter, this popped up at of the blue
Old Nov 17, 2015 | 01:10 PM
jersey68l36's Avatar
jersey68l36
I would start removing bulbs, check for changes in the draw after removing them one at a time. Hopefully it's in one of those circuits. If not, at least you started to eliminate variables. Would also use one of those battery disconnects that you see all the time at car shows until the offending circuit is located.
Swampeast Mike, thanks for the tip on the delay a source of draw. Was working on a '78 PC that has a battery draw and never did locate the cause.
Old Nov 17, 2015 | 02:02 PM
blue by you
I know what circuit it is it is in the courtesy lights so I just pulled the fuse and no draw
Old Nov 17, 2015 | 06:57 PM
mrvette's Avatar
mrvette
I pulled/disconnected/cut the wire to my 'courtesy' lights about 20 years ago....'72 vert......car that small inside, the dash lights are good enough.....
Old Nov 18, 2015 | 07:52 AM
blue by you
ok, so I went out to check out my problem, I disconnected the neg side of the battery and put the fuse back in got my test light and put on the neg terminal and cable and it lite up turned the headlight switch **** and it went out so I guess the dimmed is on the same circuit check to make sure the test light did not come on and it stayed off. So I will see if the battery drains in a day or so.
Thanks for all of you input
To electrical draw
